For sale is a like new Pioneer GM-4000F
It is in like-new condition, been used for about 4 months.
Asking 75$ OBO.
Plus shipping.
Pm me for pics.
The super-efficient GM-4000F amplifier dishes out 300 watts of peak music power & can be configured for 2-, 3-, or 4-channel operation. Its pulse width modulation (PWM) circuit efficiently outputs only the lower frequencies, which makes it ideal for powering a sub or two. The selectable high-pass & low-pass filters give you flexibility for your system, & the 4-channel speaker level input offers added control. Oversized screw-type power/ground terminals & RCA in/outputs are provided. * Peak Music Power 300 Watts * Number of Channels 4 * Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged) * Continuous Power (4 ohm) 35W x 4 * Continuous Power (2 ohm) 40W x 4 * Continuous Power Bridged (4 ohm) 70W x 2 * Frequency Response 10Hz ~ 50kHz * Total Harmonic Distortion 0.008% * Signal-to-Noise Ratio 100dB * Dimensions 12" x 2-3/8" x 9-3/8" * Bridgeable * Channel # Capability 2/3/4 * PWM Regulated MOSFET Power Supply * Screw-Type Speaker Terminals * Balanced Isolator Input Circuit * RCA Inputs 4 Channel * RCA Outputs (Pass Thru) * Speaker Level Input 4 Channel * Input Level Control Hi-Volt (400mV ~ 6.5V) * Built-in Crossover Selectable HPF/LPF (80Hz, -12dB/Oct.) (Front/Rear Independent
Asking 75$ OBO.
Plus shipping.
Pm me for pics.
