Sold FS - Phoenix Gold xs2500
double_a
JL or go home.
This amp is in perfect working order. Its a Phoenix Gold xs 2500. Its one of the older Phoenix Gold amps. Sounds great and puts out huge power. I had this thing overpowering my JLW6v2. Its a great amp made by one of the higher end companies in car audio amplifiers. I am upgrading my system and wont be needing this anymore. If someone is interested and would like pics, just let me know and ill get them for you.
Specs:
* 2 Channel Mosfet Amplifier
* PWM Mosfet Power Supply Defeatable
* Advanced Overload and Thermal Protection
* Hi Level Input Connections
* Advanced Muting Circuitry Eliminates Turn-On And Turn-Off Noises
* Metal Film Capacitors/Resistors In Signal Path
* 24kt Gold Plated High Current Power And Speaker Terminals
* Isolation Mounting Feet
* Optional XS Link For Seamless Multiple Amplifier Installation
* Frequency Response +/-1dB, 20Hz to 20 kHZ
* Signal to Noise Ratio (A-weighted) >100dB
* Max Continuous Bridged Power @ 1% THD 500 watts x 1 into 4 ohms @ 14.4 Vdc
* Max Continuous Power per Channel @ 1% THD 250 watts x 2 into 2 ohms @ 14.4 Vdc
* Nominal Continuous Power per Channel @ 1 % THD 150 Watts x 2 into 4 ohms @ 14.4 Vdc
* IASCA/USAC Power Rating 50 Watts x 2 into 4 ohms @ 12.5 Vdc
* Minimum Load when Bridged 2 Ohms
* Minimum Load per Channel 1 Ohm
* Input Signal Voltage Range 0.1 volts to 2 volts
* Crossover Type Resisitor Network, Linkwitz Riley,
* Highpass/Lowpass Crossover Slope 24 dB per octave
* Crossover Frequency Range 20-550Hz
* Factory Crossover Setting 85Hz
* Auxilary Output Channels 2 Auxilary Output Frequency Range Rnet
* Bass Boost 0- to +18dB @ 45 hZ
* Power Supply Voltage 10Vdc to 15.5Vdc
* Recommended Fuse 60 amp
* Dimensions 9.25L x 9.25W x 2.10H
Like i said, its a great amp and Im sure some of you know the quality that comes with the phoenix Gold name.
I can get Refs. for you if you are interested.
double_a
JL or go home.
double_a
Pottstown, PA
double_a
