Sold FS: Phoenix Gold x600.1
jacka
Got a Xenon X600.1 for sale. Bought it brand new in mid-April. Amp is in excellent condition, no scratches whatsoever and its a little beast. Birthsheet rated at 842 watts. Pushed out some clean power to my w3's, I upgraded to Diamond D6's which means I gotta upgrade my amplifier also. Well that's about it.. if you got any more questions feel free to ask. Looking for around 180 shipped. Paypal and money order accepted. Add 4 percent if paypal.. My ebay is turftalkisback and I've sold a set of EF-61s on here: http://www.caraudio.com/forum/showthread.php?t=165921&highlight=jacka
Here are the pics:
::: Changed to 160 shipped after looking at prices on ebay :::
XeTUNE™ – Advanced input and signal processing circuitry
Top-Mounted Controls
24 dB / Octave Crossover
Continuously Variable from 40 Hz to 400 Hz
41-Detent Potentiometers for Precise Settings
Continuously Variable Subsonic Filter (5 Hz to 55 Hz)
Twin-T Variable 0 – 18 dB Bass Boost at 45 Hz
Auxiliary Outputs Route Full Range Signals
XeFlow™ – Thermal feedback system with output optimization
Bottom-Mounted Extruded Aluminum Heatsink
Expanded Metal Mesh Intake & Exhaust Vents
Ultra-Quiet Variable Speed Fan
Temperature Monitoring with Automatic Output Optimization
Superbrite 5mm LED Power Indicator
XeLOAD™ – Full power with automatic load sensing
Load Sensing Optimizes Power Supply and Output Stage
Maximum Power Output From 1 - 4 Ohms
Class D Circuit Topology For Less Electrical System Strain
80% Average Power Efficiency Means Less Wasted Heat
Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
4 Gauge Power Terminals with Removable Rubber Grommets
Fully CEA-2006 Compliant Power Ratings Ensure Accurate Specs
Optional LPL44 (Low Pass Level) Controller Allows for Driver's Seat Adjustment of Bass Volume
Optional RMD (Remote Monitor Display) Allows Monitoring of the Amplifier's Battery Voltage, Power-On, and Thermal / Overload Status
Your birthsheet will be in that range, over 800 for sure. The SQ is awesome, the power is very clean, you'll love it.
jacka
jacka
CA
jacka
michigan born
    May 14, 2026
michigan born
    May 14, 2026
