FS Phoenix Gold Titanium 600.2 & 500.4
legendndisguise
Funky
354
9
MD
1.) Phoenix Gold Ti 600.2
2.) Phoenix Gold Ti 500.4
1.) The 600.2 was only used for a couple of months in my Honda I had years ago. Cosmetically I would give it a 9/10 due to some light blemishes on the case. It was functioning 100% when removed and has sat ever since so I would rate it a 10/10. I do have the LPL for this amp as well and it was never used.
Class A/B 2 channel amplifier
24dB HP/LP variable crossovers
Crossover configured aux output
Remote Low Pass Level control (LPL)
Dimensions: 16.0L x 10.0W x 2.25H
150W x 2 (4 ohm stereo)
600W x 1 (4 ohm bridged)
Input Voltage Range 10.5 to 15.5 volts
2.) The 500.4 (NOT FUNCTIONING) was in my Honda before the 2 channel was. Cosmetically would be a 6.5/10, quite a few blemishes and some odd looking marks. Functionality, I can't really give a number considering it is not working right now and I am not sure to the extent of repair it needs. The front right channel was not functioning correctly and produced a lot of noise. At the time the shop that installed it just bridged the rear channels in order to power all four interior speakers. After some months the amp just shut off (blown in line fuse). As soon as I changed the fuse, it blew instantly. I checked the continuity between the positive and ground on the amp and it is shorted. I really don't know to the extent of the damage. A friend of mine was going to buy it and have it repaired, but he never did.
Power output:
Into 4 ohms Stereo @ 14.4 Vdc 4 x 75 wrms
Into 2 ohms Stereo @ 14.4 Vdc 4 x 125 wrms
Into 4 ohms Bridged @ 14.4 Vdc 2 x 250 wrms
Minimum Speaker Load, Bridged 2 ohms
Minimum Speaker Load, Stereo 1 ohm
Fuse Size, Stereo 4 W / Stereo 2 W / Bridged 60 / 80 / 80 amp
Dimensions, Chassis (inches) 15.00 L x 9.00 W x 2.25 H
Dimensions, Overall (inches) 16.00 L x 10.00 W x 2.25 H
Bass Boost 0 to +18dB @ 45 Hz
Crossover Slope 24dB per octave
1.) 600.2 - $235 shipped OBO
2.) 500.4 - $95 shipped OBO
I ship USPS with insurance and delivery confirmation.
I have more photos if you need them, just PM me.
Also, I hope this helps. My username on eBay is legendindisguise if you want to check feedback, it is also the same on my.is.
Nathan
Open to any offers on the 500.4
I am sick of looking at it. It will cost $144 for Phoenix Gold to fix it.
Right now for me to ship safely and properly it would cost roughly $22.
legendndisguise
Funky
legendndisguise
MD
legendndisguise
michigan born
    May 14, 2026
michigan born
    May 14, 2026
