Sold FS: PDX4.100 - JL 12w6V2 - Deadener - Arc12
mattldm
Trying to get noticed
I have decided to sell a few things to clear up some space in the garage...
First up is an Alpine PDX 4.100. This amp is like new with original box, paperwork, and accessories. Birthsheet rated at 131 watts per channel!
(Note: the stacking feet, and mounting screws are not included)
everything on the amp is 100% functional, it is like new.
PDX4.100 - $240 shipped in the 48 states Pm for shipping to Alaska/Hawaii
Next is my JL audio 12W6v2... This sub hits hard, low and plays very loud with good SQ! The reason I am selling is that I want to replace it with a smaller sub to take up less space in my truck. The sub is in excellent condition with a couple light scratches on the cone but nothing that affects the sound. There is also a slight blemish on the magnet but again it does nothing to the sound. I have been running this with a PDX1.600 and it rocks!!!
The sub is currently mounted in a box that I built for it. The box is 1.29ft^3 gross and 1.22ft^3 net after the sub displacement. The box is built from .75" MDF, glued, nailed. stuffed with 1lb Acousta-stuff polyfill and covered with parts-express charcoal carpet. The box is 22.5W x 14H x 10D. I will sell the sub together or separately and will also sell the box by itself if someone wants just the sub.
JL 12W6v2 - $210 plus actual shipping
Box - $25 plus actual shipping
Both box and sub together - $225 plus actual shipping
I have 13' of a roll of Raamat = 18ft^2 (this is a little more than 1/4 of a roll) ($30 plus shipping)
I also have 4 sheets of Second skin Damplifier (8ft^2 total) each sheet is 2 square feet. ($20 plus shipping)
If somebody buys Both raamat and Damp together i'll do it for $45 plus actual shipping.
Also for sale NON WORKING Arc Audio ARC12d2 sub. The motor/magnet of this sub has shifted and is causing the voicecoil to bind up. The cone will not move unless it is forced. I attempted to realign the magnets and was unsuccessful. I spoke to Arc about this and they said that the sub MAY be repairable, but it may not!!!
This is one outstanding SQ sub!!!
Make me an offer!! ill consider anything, $15 plus shipping to start?
If you have any questions feel free to ask...
There are only three things that I will consider trades for:
DLS Iridium 12i sub
Image Dynamics IDQ12 - version 3 only
Arc Audio ARC12 - one that works, lol! :p
Thanks
Finally!! that was the best price that i've seen personally
Yeah it was pretty low but I got a good deal on it when I bought it! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
How unaligned are the slugs? Can you get pics of it without the boot? Also, I'm assuming you tried playing it with the shifted slugs, which musta been a hellish coil rub, so I'm guessing the coil is no good?
As you can see I'm tempted for a new toy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
And about how much power can it take daily?
Well its hard to tell how misaligned they are really, this is my first experience with a damaged sub!
I tried shifting the magnets around and they move with light taps (I used a block of wood to tap)... I removed the boot and the magents look fine other than a small chip (very small) missing from the edge of the magnet. I was able to tap the magnets back and forth and had varying success in allowing the cone to move. when I tapped it one way the coil would rub on one side, then the other, etc...
The speaker actually played fine other than the coil rubbing and causing the noise I really dont think the original coil rub was doing any damage to the sub at all.... However once I tried to shift the magnets myself I made it worse! //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I ran it off of a Sundown 1000d at 1ohm (1000 watts) very low gain setting and also off a PDX1.600 again pretty low gain... It can handle the power, Arc rates it at 350wrms but it can take more if used properly.
mattldm
mattldm
So Cal
phantom240
