Sold FS: OS PPI Flat Pistons Pro, Directed 1100D, and other amps
FurbiesAndBeans
1.- First off are the old school PPI Flat Pistons Pro. These are SVC 4 ohm. They're 12s. Here's the specs on them:
Normal Power Handling 300W rms
Voice Coil Diameter 3”
Voice Coil Type / Former edge wound/Kapton
Resonant Frequency 43Hz
Qts-Total Damping 0.52
Qms- Mechanical Damping 2.51
Qes- Electromagnetic Damping 0.66
Vas- Equivalent Compliance Volume 43.97 Liter
DC Resistance of V.C. 4W / 8W
Sensitivity(SPL at 1W) 89.31 dB
Linear Excursion ±5.5mm
Peak to Peak Excursion ±13mm
Mms- Total Mass 114.7 grams
Sd- Piston Area 0.0512 sqM
Bl- Magnet Product 13.74 TM
Diaphragm Material carbon fiber/Nomex honeycomb
Basket Material cast aluminum
Net Weight 24.18lb
Dimensions 12.27” dia. X 4.75” H
Mounting Diameter 11.125” dia.
I'm going to say 130 + shipping for each. Or 250 + shipping for both. I will take offers on these though because I'm not sure how much they're worth. PENDING SALE
2.- Directed 1100D. This amplifier works perfectly, but has some scratches on the heat sink. It's also missing one of the mounting pegs. It doesn't come with the bass remote. 150 SHIPPED, or best offer.
Specs:
Output Power at 14.4V (20 ∼ 250Hz):
1 x 425W @ 4 ohm (0.5% THD)
1 x 750W @ 2 ohm (0.75% THD)
1 x 1100W @ 1 ohm (0.9% THD)
S/N Ratio: >85dB
Freq. Response: 20Hz ∼ 250Hz (+0,-1dB)
Damping Factor: 50 (typical)
Fuse: 2 x 40A
3.- MTX Blue Thunder Pro 752. This amp is also missing one of the mounting pegs, but it works perfectly. I heard this amp is very underrated, it's suppose to do around 75x2 @ 4 ohms. 50 SHIPPED.
Specs:
Output Power at 12.5V:
2 x 37.5W @ 4 ohms (
2 x 75W @ 2 ohms (
1 x 150W @ 4 ohms bridged (
S/N Ratio: >110dBA
Damping Factor: >200
Freq. Response: 20Hz ∼ 20kHz (±0.25dB)
Fuse: 30A
4.- Absolute EVD-2200. This amp is in mint condition. The gains were always set very conservatively. This comes with the bass remote. 140 SHIPPED
Specs:
# Evolution Series Class D Monoblock Car Amplifier
# RMS Power Rating:
* 4 ohms: 360 watts x 1 chan.
* 2 ohms: 650 watts x 1 chan.
* 1 ohm: 1020 watts x 1 chan.
# Max power output: 2200 watts x 1 chan.
# MOSFET power supply
# LED power and diagnostic indicators
# Tuned Bass EQ (0-18 dB bass boost)
# High current amplifier
# Low level RCA input
# Soft delayed power on
# Preamp RCA outputs
# Double sided PCD design
# Thermal and short circuit protection
# Variable low-pass filter (30-500 Hz, 24 dB/octave)
# Subsonic Filter (10-50Hz)
5.- MA Audio HK302SX. This amp has a couple of scratches, and one noticeable scratch on the LCD. This amp works very good, but the specs might by a little over rated. It's stable down to .5 ohms. 200 SHIPPED
Specs:
# 1400W RMS 2-Channel High Current Amplifier
# 175W RMS x 2 @ 4 Ohms Stereo
# 300W RMS x 2 @ 2 Ohms Stereo
# 450W RMS x 2 @ 1 Ohm Stereo
# 700W RMS x 2 @ 0.5 Ohm Stereo
# 1400W RMS x 1 @ 1 Ohm Bridged
# Digital LCD Display (Voltage, Temperature & Output Level)
# Platinum Plated Connections
# Quiet Fan Cooling System
# High Quality Power & Protection LED’s
# Thermal / Short / Overload Protection Circuitry
# 0-18 dB Variable Bass Boost
# 40-250Hz Variable High Pass Crossover
# 40-250Hz Variable Low Pass Crossover
# Remote Bass Control
# THD @ 4 Ohms
# THD @ 2 Ohms
# THD @ 1 Ohm
# S/N Ratio: >90dB
# Channel Separation: 60dB
# Frequency Response: 20-20kHz
# Input Voltage Range: 200mV - 8V
# Input Impedance: 10k Ohms
On to the pictures:
Sounds good.
I might be interested in the Directed aswell. Got any p0rn shots of the monoblocks?
thanks!
I'll try to get some of the Absolute. The directed is currently installed in my dad's car. If i sell the absolute, then i keep the directed, and visa versa cuz he needs an amp, lol.
NO worries. I'll take one or the other, its for my brother anyhow //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Let me know what one you want to part with first!
K will do. I'm just gonna wait for my friend cuz i'd rather do it locally than having to pay for shipping and stuff. If that falls through i'll let you know first thing. I will, however, sell you the MA right now if you want =)
Battery trade deal for the MA?
If not I can wait it out for the Absolute I am not in that big of a hurry //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll hold out and wait and see if your buddy jumps on the Absolute.
I am waiting for my comps to show up so I can send the money off to the seller before I drop anymore dollars! Unless its on stripers and beer.
/bump for you!
Yep I am definetily interested in a trade //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That is almost identical to my Powerbass amplifier with a few changes.
FurbiesAndBeans
FurbiesAndBeans
Corona, CA
FurbiesAndBeans
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
