Rockford Fosgate Power 1001bd
500 watts RMS x 1 at 4 ohms
1000 watts RMS x 1 at 2 ohms
Class bd technology
requires 4-gauge power and ground leads and a 100-amp fuse and fuse holder — wiring and hardware not included with amplifier
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz)
bd Sync — now you can bridge together two separate Rockford Fosgate Class bd amps (with an optional cable) to power one woofer
subsonic filter removes frequencies below 20 Hz for increased efficiency
13-1/8"W x 2-3/8"H x 9-7/8"D
In fair cosmetic condition. Will clean it up as best I can before I send it out. No sides but functions 100%. Hooked it up today on my JL 13w6v2 and it sounded awesome!!!!
Will add more pics soon. Looking for 200 plus shipping. Open to trades. Looking for a powerful 4 channel or 6.5 woofers and tweeters.
Let me know if you have any questions.
Thanks for looking
Sent from my SAMSUNG-SM-G935A using Tapatalk
Class bd technology
Thanks for looking
