FS: Old School MB Quart 3 way components QM 6.5/4/1
bergend2
Set of MB Quart woofers/mids/tweets. Didn't have the x-overs, so I have included a set of Pyramid 3 way x-overs to go along with them.
Mb Quart Qm 160 6-1/2" Automotive Midbass 4 Ohm
Originally part of a high-end car component system, the MB Quart QM 160 is an exceptional midbass driver. Built in Germany, it uses a butyl rubber surround, pressed paper cone, and a unique aluminum voice coil cap for extended midrange response. The true 6-1/2" frame has a multitude of mounting holes for drop-in replacement for just about any stock 6-1/2" speaker. Does not include tweeter or crossover, but nonetheless is an excellent buy at this price. Limited quantities.
Specifications: • Power handling: 70 watts RMS/100 watts max • VCdia: 1" • Le: 0.60 mH • Impedance: 4 ohms • Re: 2.65 ohms • Frequency range: 60-4,000C Hz • Fs: 58 Hz • SPL: 90 dB 2.83V/1m • Vas: 0.68 cu. ft. • Qms: 4.50 • Qes: 0.77 • Qts: 0.66 • Xmax: 3mm • Dimensions: Overall diameter: 6-1/2", Cutout diameter: 5-5/8", Depth: 2-1/2".
Couldn't find the specs on the QM 100's, and the tweets did not have a model number on them. They are MBQ's, but they appear to be part of a convertible component set.
All the speakers are used, but in good shape. No grills are included. The x-overs are brand new.
$125 + shipping
Shipping not included
price without the crossovers? did you personally test every driver with an amplifier to ensure proper operation with no coil buzzing?
thanks - great speaker system here. MB Quart Q series is a top notch speaker set - comperable to $1000 sets.
I haven't tested them fully, just hooked them up to some low HU power quickly, then they sat for ~6 months. I guarantee no DOA, if they don't work, just send them back and I will refund you all costs.
nice set here. my old school mbquart 6x9's were the only ones i have had that kept up with 146.6db substage on eclipse head unit power. clean and clear, right through the gas canal caps. btw, those tweeters mount right to those 6.5's. you screw them in through the back of the basket where the wire channel comes through. some good German goodness here
bergend2
bergend2
Milwaukee
bergend2
