I bought this amp in June from Crutchfield, it is still under manufacturers warranty. Everything that originally came with the amp is included. Comestically from the top the amp is a 9.5/10, but I never used the side covers and as a result on one side they are slightly stratched. The other side is much better and you cannot see the side covers anyway. In addition I am missing one of the four little allen wrench screws that hold the side cover, but again these can easily be replaced and cannot be seen.
Here are the specs:
» 4-channel car amplifier
» 100 watts RMS x 4 at 4 ohms (200 watts x 4 at 2 ohms)
» 400 watts RMS x 2 in bridged mode (4-ohm minimum impedance)
» CEA-2006 compliant
» front and rear high- and low-pass filters (variable 50-500 Hz at 12 dB per octave)
» multiplier x10 switch converts filters to variable from 500 to 5,000 Hz
» LED clipping indicators
» preamp-level inputs and outputs
» front end defeat bypasses gain and crossover controls
» fuse rating: 30A x 3
» requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
» 11-1/2"W x 2-3/8"H x 16-3/4"D
I am looking for $275 shipped and insured. I will also trade for an RF Power T4004.
Top Without Cover
Top Mounted Controls
Top With Cover
Stratched Side of the Covers
Good Side of the Covers
Accessories
I am looking for $275 shipped and insured, but would be willing to trade for a RF Power T4004.
Here are the specs:
Top Without Cover
Top With Cover
Accessories
