Sold FS Massive Audio P3000.1 $245 shipped
snarl2004
new price!! 245 shipped
I have a massive audio p3000.1 for sale. It is a little scratched up and has some sand under the plexi on the top of the amp. I would probly give it a 6/10 cosmeticly.
RMS Power Output: 3000w RMS @ 2 Ohm
Peak Power Output: 6000 watts
Frequency Response: Hz - 180 Hz
Input Sensitivity: 120mVrms ~ 5.0 Vrms
Ohm Load Stability: 2 ohm
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 8.70" x 2.6" x 38"
it works but it sounds like something may be loose inside im not sure i havent opened it up, very well could be a heat sync not screwed down all the way or something idk. it was like that when i bought it from the previous owner about a year ago. it does work 100% though.
im sure the plexi can be taken off and the sand removed i just havent tried yet.
make sure you have a strong charging system for this amp though. if the voltage drops below 11.5 then the amp will stop playing for a slip second then start up again. it doesnt turn off or anything it just stops playing for about 1/4 of a second, but if your voltage stays above 11.5 youve got nothing to worry about.
ONLY trade would be JVC Arsenal series HU
Ok so i took the amp apart. At the end of the plexi on each side there is a small bead of glue. If you break that bead you can remove the plexi and get the sand out, then all you have to do is put a little but of glue where the old was.
Also i figured out what was rattleing. End of a screw broke off. I cant fix it but it dosnt effect the preformance of the amp at all and only rattles if you shake the amp.
i cant believe no one wants this amp for this price
if i had the money , i would be all over this....
i cant sell my amps as well.....seems like nobody wants to come out of there pockets right now...no matter how cheap we price things...//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
if you were to want to trade for some smaller amps let me know...
basicly any current model kicker has on their website. I just want to make sure I can get a wiring harness and everything I need for it. However I have a jvc kd-g320 and if the same harness I use for that works fir the arsenal series then I would be interested.
snarl2004
snarl2004
mass
Westernohiopc
