Sold FS: Lots of stuff...Cleaning Out My Garage
SentraStyle
One pair of Orion XTR10D subwoofers. Brand new. Purchased them for a friend that swore they'd pay me back...but never did. I took them out of the box...looked them over...and put them back in. Frequency Response: 30 - 500Hz, Peak Power: 500 Watts RMS Power: 250 Watts, Sensitivity: 96dB, Dual Voice Coil 4 Ohm $150 pair.
Polk Audio DX3065 6.5" Component set (Like Momo's)!!! Set contains 6.5" mid, 1" silk dome tweeter, and crossovers. These components are some of the best components ever made by Polk Audio. They sound just like the original MOMO series but without the fancy look. The good thing about these components over the MOMO's is that the DX's will actually fit in your doors because they have a shallower mounting depth than the MOMO's. Comes will all mounting hardware. I have one new set for $175 and one gently used set for $150.
Infinity 605CS 6.5" component set Brand new Infinity 605CS 6.5" component set. Plus One Woofer Cones - Each speaker size uses a cone about 30% larger than competing models of the same size. This is accomplished using our new basket
design and hi-roll surround. The benefits of Plus One™ are greater bass output and a two-to-three dB increase in efficiency versus competing brands. That's right two to three dB! Hi-Roll Rubber Surrounds - The motor structure in Reference is longer than competing models. This longer motor structure uses a taller surround. The result is longer X-max and more bass output. Silk-Dome Tweeter - This is not a commonly used w-dome, but a true edge-driven dome like those found in high end home audio loudspeakers. Our silk dome material ensures smooth response, free from harshness and fatigue to 20kHz, even at high output levels. I-Mount Tweeter Mounting System - This patented mounting system facilitates effortless flush, angled, or surface mounting of the component system tweeters. $100
FS: Three 1-Farad Monster Cable Capacitors w/ Gold Triangle Buss Bar (Connector) Three 1-Farad Monster Cable Capacitors . Brand new...only taken out of boxes to mount in my installation...they wouldn't fit so I need to sell. They are white and come with a gold triangle buss bar to connect the three caps together. $300
K-40 RD650VG2 Radar/Laser Detector Detects X,K and Superwide Ka band Radar and Laser Features include: Unique "5-window" design Helps this detector pick up
laser signals front and rear, even off axis signals. VG-2 Shielding K40 systems are passively and actively designed to prevent detection from the police VG-2 Gun (radar detector detector). Pulse Protection Immediately alerts you to police "Instant on" radar. Signal Alert Indicator Four LED's illuminate as the strength of the police radar signal increases. Band Indicator Audio and visual alerts combine to alert you to radar or laser signals. Filter Button Reduces non police signals without sacrificing performance to true police radar. This unit has been used for a few months but is in flawless condition. All manuals, accessories, and box is included. $200
Bazooka EL1500 (500 x 1 RMS @ 2 Ohms) Brand new Bazooka EL1500 subwoofer
amplifier. Voltage: 10.5-14.4 Sensitivity: 450mv - 8v Frequency Response: 20Hz-20kHz Fuse (4): 15A @ 60A Crossover: Low Pass ONLY Protection: Speaker, Ground, Thermal Max Power Output: 700 Power @ 4 OHM: 385 x 1 Power @ 2 OHM: 500 x 1 Signal To Noise Ratio: 100 dB Hi Input Level: 1.0 - 10.0V Batt. Voltage
Rng: 10.5VDC - 15.0VDC Xover Rng: 50-250Hz,sloped @ 12db/Oct Bass EQ: 12db @ 45Hz Remote Control: *Optional* (ELA-BCM). $150.
Viper800ESP w/ Lots of Accessories. I am selling it with (2) 530T window modules, 520T backup battery, 506T glass breakage sensor, 500T motion/tow sensor, and add on remote start 551T. This is one of DEI's top of the line alarm. Some of the features of this alarm are: * 4-button transmitter (1) * ESP Transmitter Code Linking * Custom configure memory seats and mirrors * 7 Receiver Channels * Built-in Power Door Locks, and Parking Light Flash * Built-in Domelight Supervision, and Power Trunk/Channel * 8 Zones * XHF (Extra High Frequncy) Unit comes with all original boxes, manuals, etc. Only comes w/ one transmitter. Will not separate...don't ask ...$450
Used AudioControl 4XS crossover. Features: 2 or 4 Channel Electronic Crossover,
State-variable 18dB/Octave Active Crossover, Four Channel Two-Way or Two
Channel Three-Way Operation, Module Programmable Crossover Frequency, Output
Level Controls, Programmable Frequency Match (PFM), Subsonic Filter for Subwoofer Control and Protection. It is grey in color and shows some wear and
tear...but performs flawlessly. I am looking for $100.
A brand new set of Alpine's Flagship component set. These speakers will rival just about any other set of components out there. They are bi-ampable, have over 90 different listening setups (depending on how they will be installed), and are just an awesome set of speakers. The only reason I am selling them is because I bought some MB Quart QM218.61Q components. I had one set of the Alpines in my doors and they were amazing. I had this set for some kick panels which I haven't made yet. These speakers list at $399...I would like to get about $250 for them.
Alpine Setup...MRV1507, MRVF307, MRVT407, and 4 SWR1040 type R subs for $1100. Will separate...but only if all sells (MRV1507 $380, MRVF307 $250, MRVT407 $150, and SWR1040 $100/each).
will u go down on da mrv1507?
Hmmm....did you happen to notice the post date and even the LAST post date on this ad? 2003.....6 years ago....
So doubt he has the items for sale...BUT if he still does...he may want to go down on the price...
SentraStyle
SentraStyle
Kissimmee, Fl
Wakeup
