messed around and spent some money I should not have
so I have to sell something else out of the collection
so up for sale is a old school powerhouse
lanzar optidrive 2500 (black chasis prebuyout)
its a 2 channel amp
does
250x2 @ 4ohm stereo
500x2 @ 2 ohm stereo
1000x1 @ 4 ohm mono
thats rated specs
I have seen these bench at least 1200w @ 4 ohm mono, and over 1500 @ 2 ohm mono (with proper cooling external fans may be neccesary)
It has the black heatsink, not the newer post buyout silver chasis, adn this is and original lanzar otpidrive, non zed audio build
it has some scrathces on it, as it old, at least a 8/10 and thats being rough, but its black so even those scratches dont really show up that much
it has 2 8ga grounds, and 2 8ga power wires (it hangs out the chasis like the old us amps power house amps)
but they can soldered together if you like
and there is a ton of stock wire left , only cut once
I have the original box, but no manual--have no idea where is it
$400 shipped OBO
Internal SHOTS
http://photobucket.com/albums/v693/newtitan/?action=view&current=IMG_4089.jpg
http://photobucket.com/albums/v693/newtitan/?action=view&current=IMG_4091.jpg
mechanically 10/10 as im running it right now on sub duty
, but IMO its clean enough to run on components as I tried it and it was very clean to my ears
and remember this is class a/b not D,
off the box
@exclusive CPS technology
@Adjustable Subwave boost up to +14db @ 45 hz
@Built iun electronic crossver when amp is used a Bass amp only
@Pulse Width Modulated Mosfet POwer Supply with Spereatley Regulated Power supply for Amplifier Front end
@Stable into 2 ohm loads
@High Current/High Volage Device Discrtee Darlington Output Design
@Stable from 9-16V DC
@Muted turn off Circutiry
@Isolated Input Section for noise protection
@Optically Isolated Power Supply
@Heavy Duty Built in Speaker Terminals
@Proetected from Over or Under Voltage, REversed Polarity, @SPeaker SHorts, Thermal OVerloads, Clipping, and DV offsets
if you need references cool--email me, I have a ton, if you need physical chasis pics, email me and Ill ake them as Ill have to dissasemble my rack and power wire
so if you want the external pics, be at least semi interested as the uninstall takes awhile
its a 2 channel amp
does
250x2 @ 4ohm stereo
1000x1 @ 4 ohm mono
thats rated specs
$400 shipped OBO
Internal SHOTS
off the box
