FS: Kicker xs1000
  • 5
eg9
Kicker zr1000 w/ SWX subwoofer xover module
Fair shape to me, cosmetically a 7/10. Needs to be cleaned/touched up and it is missing one of the mounting feet. Functional absolutely 100% and sounds great! I'm just a Zed junkie so this has to go.....
$350 shipped
Included in price, Tracking info provided when shipped.
It is a nice amp. But it is not an xs series amp. The xs series was a OS "cheater amp" from that same period. That is just a ZR1000. Still a nice amp, but no xs100 or xs50 ... just an FYI. NOT trying to be a d i c k ...
ZR 1000 is a 250wrms x 2 amp . 500 x 2 MAX power.
XS100 does 1000 x 1 @ 1ohm @ 12.5vdc almost 1400 rms @ 13.8 - 14.4 vdc
Yea auto correct did the xs1000, not sure why.
I just saw your good feedback marks, and figured I would say something, so no one got peeved if they didn't catch it ....
P.S. auto correct sux ......LOL....
Yea no problem, good lookin out!
And yes it does lol.
Maybe I'll get lucky and a mod or admin will fix the title.......
I have both the XS100 and ZR1000 and when it comes to high voltage (ZR1000) vs. high current (XS100), high voltage wins. Lowering ohm loads to get more power decreases efficiency, creates more heat, and in this case puts out less power than the ZR1000. The ZR1000 is capable of 1900W+ dynamically (bass notes). Both amps are similar like the old Orion 2100 HCCA vs. XTR-2250. XTR = high voltage and more powerful
Just trying to educate here...love the amp BTW, it is a BEAST! GLWS
Sorry, I haven't benched a xr1000, so I was going by specs on it ... I understand high current vs high voltage .... also understand that these are two completely diff amps, that look similar... I just was trying to save the op some possible grief ...
I'm one of your subscribers BigD btw. ....
BUMP, for a nice AMP ....
Thanks guys, no worries!
More real life input on audio equipment is always welcome!
I've actually ran the xs100 been many years ago but loved it. I did switch it out for the high current version of the Autotek 333, I think it was the Autotek mxi100hc maybe?
Btw ...........I still have the original box for my old xs100.
441
932
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
eg9
eg9
Winston-Salem, NC
eg9
pfft
    May 1, 2024
pfft
    May 1, 2024
