Nice used JL e4300 & e1400d amps for sale.
200 for both or 110 each.
e4300 110 obo
Class AB 4-Channel Amplifier
Absolute Symmetry Class AB Circuit
Differential, Noise Cancelling Input Topology: RCA jack inputs(low-level) and multi-pin jack(high-level)
On-board crossover: State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50-200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output: Pass-through type
CEA-2006 Compliant
RMS Power Rating (14.4V):
4 ohms: 70 watts x 4 chan.
2 ohms: 110 watts x 4 chan.
Bridged (4 ohms): 220 watts x 2 chan.
Bridged (8 ohms): 140 watts x 2 chan.
RMS Power Rating (12.5V):
4 ohms: 45 watts x 4 chan.
2 ohms: 75 watts x 4 chan.
Bridged (4 ohms): 150 watts x 2 chan.
Bridged (8 ohms): 90 watts x 2 chan.
Frequency Response: 10 - 25kHz
Damping Factor: >200 @ 4 Ohms / 50Hz, >100 at 2 Ohms/50Hz
S/N Ratio: >104 dB referred to rated power(A-weighted, 20Hz-20kHz noise bandwidth)
Input Range: 200mV - 8V RMS
Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
Slew Rate: +- 22V/us
Dimensions: 13.8" L x 9.25" W x 2.36" H
e1400d 110 obo
Class D Monoblock Full Range Amplifier
High-Damping Class D Circuit with discrete contorl circuitry
Pass-through RCA outputs
On-board crossover: Variable Low-Pass Filter: 20 -200Hz, Selectable Slope
High level inputs
CEA-2006 Compliant
4 ohms: 320 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
4 ohms: 200 watts x 1 chan.
2 ohms: 400 watts x 1 chan.
Frequency Response: 10 - 250Hz
Damping Factor: >500 @ 4 Ohms / 50Hz,
Dimensions: 11.81" L x 9.25" W x 2.36" H
e4300 110 obo
CEA-2006 Compliant
e1400d 110 obo
High level inputs
CEA-2006 Compliant
