Sold Fs: Jl Audio 450/4 - $300 Obo
sundownz
Pro Seller
Supporting Vendor
FS: JL AUDIO 450/4 - $300 OBO
If you have an offer MAKE IT... I will not answer a PM that says "What is the lowest you will take?" NO TRADES!!!!!
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
* Channels 1 and 2:
o Rated Power (stereo mode): 150W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
o Rated Power (bridged mode): 300W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
* Channels 3 and 4:
o Rated Power (stereo mode): 75W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
o Rated Power (bridged mode): 150W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
* Peak Power Output 900 watts approx.
* Differential-Balanced Input Topology: (2 pairs of inputs)
* Channels 1 and 2 Crossover:
o Fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Channels 3 and 4 Crossover:
* THD at Rated Power:
* S/N Ratio*: >108.5 dB below rated power
* Frequency Response: 5 Hz-30 KHz (+0, -1dB)
* Damping Factor: >200 @ 4 ohm per ch./50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Preamp Output: 2-channel (Pass-through with selectable input sourcing)
* Bass EQ: +6 dB (variable boost up to +15 dB with Remote Bass Option)
* Infrasonic Filter (Channels 1&2 only): defeatable 24dB/octave at 30 Hz
* Speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
* Fuse Rating: 60A
* Dimensions: 13.4"L x 9.25"W x 2.36"H
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
SoCalBean420
