FS: JL Audio 300/4v2 & HD750/1
05impalaSS
300/4v2
I bought this amp new roughly 2 months ago. It has 2 slight scratches as shown in the pics other than that powers up and works perfect! I used this amp for an Active set up for my Seas Components and it was outstanding!!!
HD750/1
I bought this amp new roughly 2 months ago with the 300/4. The 750/1 is in perfect condition but 1 of the allen bolts that hide the mounting screws is broken, I believe it is the bottom right one. I am including the stacking kit which I just received from crutchfield and it also has brand new plugs for the speaker wire and power/ground wire. I have the original box for it and printed off manual. I had this running my 2 12" Eclipse SW8122.4 subs and pushed both nicely!!
300/4v2 $300 Shipped
HD750/1 $425 Shipped
Will sell both for $650 Shipped
I will take Best offers, but please no low balls.
Both shipped to the lower 48
HD 750/1
mono subwoofer amplifer
750 watts RMS x 1 (1.5 - 4 ohms per channel)
variable high- and low-pass filter (50-500 Hz 12 or 24dB/octave)
subsonic filter and output polarity control.
removable power and speaker plugs
optional wired remote for level control
Class D amplifier design
MOSFET power and output stages
differential-balanced inputs eliminate noise from your vehicle's electrical system
speaker- and preamp-level inputs
preamp outputs
4-gauge power and ground leads and a 80-amp fuse recommended - wiring and hardware not included with amplifier
# 10-3/4"W x 2"H x 7-7/8"D
300/4v2
Patented Technology: Absolute Symmetry Class A/B Circuit
Differential-Balanced Input Topology: 2 pair of inputs
On-board Crossover: Fully-variable (50 Hz - 5 kHz), selectable-slope / mode (12 or 24 dB / octave, LP or HP) for each pair of channels
Speaker output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
Rated Power (4 Channel Mode): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (Bridged to 2 Channel): 150 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio : >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Slew Rate: +25 V / uS @ 4 ohm per ch.
Left to Right Channel Separation: >75 dB @ 1 kHz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
if any of you are on the other audio forums I have my Eclipse CD8443 for sale as well.
but I am open for reasonable offers . Need this stuff gone to fund the installation of the new equipment in my truck
05impalaSS
05impalaSS
Fountain, Co
05impalaSS
