Sold Fs: Jl 300/2 - $200 Obo
sundownz
Pro Seller
Supporting Vendor
FS: JL 300/2 - $200 OBO
If you have an offer MAKE IT... I will not answer a PM that says "What is the lowest you will take?"
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
Rated Power (2 Channel Mode): 150 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (Bridged Mono): 300 W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio: >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate: �25 V / �S @ 4 ohm per ch.
Left to Right Channel Separation: >75 dB @ 1 kHz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.27 in.
340 mm x 235 mm x 58 mm
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
