Sold FS: Hifonics XXV Sampson
dobbietwo
Like new Hifonics XXV Sampson. Monster amp! 37.8" x 11.8" x 2.7" Runs at 14.4, 16 or 18 volts. 1 ohm loads are 8000x1 at 14.4, 8900x1 at 16v, and 10200x1 at 18v and no its not overrated!! You'll need 2 800amp fuses to protect this badboy! Amps weighs over 50lbs.
Reason I'm selling is its just too much amp for me sound wise and dimension wise. Amp is like new no scratches or anything. Run time is less than 1 hour. Make a offer! I will accept a layaway on this depending on terms. Ask any questions you might have! Asking 1349.00.
Dang people, there is suppose to be a pic with the date and my user name but it didn't load up. I'm still trying.... give me a break!!//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
2 800 amp fuses? So this amp draws 1600 amps? Considering that a run of 0 gauge can handle 250 amps roughly, you need 12 runs of 0 gauge to run this?
manual only states that it needs 800 amps of fusing.Doesn't say anything about 2 fuses as it does for some of the other amplifiers.not trying to bust your balls but you posted the manual.I would think a 400 amp fuse in each of the 2 power lines would do the trick
Thanks for the response! You know your probably right. I will have to call Hifonics just to clarify that for my buyer. Just sold it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
dobbietwo
dobbietwo
Texas
basebalz13
