Hifonics BXi1208D - About 5 hours of total playtime on it - 9/10 cosmetics (has a tiny scratch in the chrome and 2 pin hole sized nicks in the heatsink), 10/10 function. 145 shipped.
* Type: Mono Block
* 1-Ohm Power Rating 1x1200
* 2-Ohm Power Rating 1x900
* Turn-On Delay/ Mute
* Frequency Response @-3dB: 20-250Hz
* Damping Factor: >250
* Signal To Noise Ratio: > 95 dB
* THD + Noise:
* Variable Input Level Control (RCA/Unbalanced): 0.2V - 9V
* Variable Input Level Control (Mini DIN Balanced): 0.4V - 18V
* Input Impedance: 47k Ohm
* Input Impedance: 20k Ohm
* Power and Specific Diagnostics LEDs
* Protection DC, Short Circuit, Overload
* Power Supply - All MOSFET: Full PWM
* Power Output Circuit Type: Ultra-Fi MOSFET
* Variable Phase Shift
* Phase Change in Degrees: 0-+180
* Variable Low-Pass 24 dB Octave: 35Hz - 250Hz
* Variable Subsonic Filter: 15Hz - 35Hz
* Bass EQ: 0-+18 dB
* Balanced Inputs
* RCA Inputs
* RCA Line Outputs
* Remote Bass Module Included (Via RJ11 Jack)
* Gold Plated Power Terminal Blocks: 4 GA
* Dimensions WxHxL: 11.41"L x 10.39"W x 2.63"H
JBL gto606c Grand Touring Series 6.5 components - Brand new, never used only opened to take pictures.
80 shipped
* Size: 6 1/2
* Sensitivity: 90 dB
* Frequency Response: 55-21,000 Hz
* Recommended RMS Power: 70W
* Peak Power Handling: 210W
* Impedance: 4 ohms
* Oversized Plus One™ Woofer Cone
* High-Roll Butyl Rubber Surround
* 1" Edge-Driven Kaladex Tweeter
* I-Mount Multi Tweeter Mounting System
* Intermount III System for Easy 6 3/4" and 7" Fitment
* 2-Way Outboard Crossover
* Mounting Hardware and Grilles Included
* Type: Mono Block
* THD + Noise:
* Bass EQ: 0-+18 dB
* Balanced Inputs
* RCA Inputs
* RCA Line Outputs
80 shipped
* Size: 6 1/2
* Impedance: 4 ohms
