Sold FS: Hifonics BXI1206d
NoPh33rRaCiNg
9.5/10 Cosmetic, 10/10 mechanical
I have been running this on my 15'' SX for 2 years at 1 ohm, never shut off on me, never overheated, gains set with dmm. I will say that a friend wanted to buy this, he had a sub wired to 4 ohms, and this amp did not seem like it did rated power at all. It did get very loud with my sx at 1 ohm though, id recommend this if you need a good budget 1 ohm stable amp.
$150 shipped
* Super D-Class Monoblock Amplifier
* RMS Power Ratings:
o 1 ohm: 1200 watts x 1 channel
o 2 ohms: 900 watts x 1 channel
o 4 ohms: 450 watts x 1 channel
* BXi AccuCross™ active electronic cross-over permits full adjustment of:
o Bass EQ, Subsonic Filter, Low-Pass & Phase Shift features
* RCA Input level control permits matching the amplifier input level (gain) to the CD/Receivers output level. Or the Balanced Input will accept BLD Line-Driver levels from 4 to 18-volts.
* The Brutus BXi bass remote controls the subwoofer output signal from the drivers seat.
* For multi-amp daisy chaining, the RCA line inputs transfer the pure untouched audio signal directly to the line output RCA jacks, bypassing any crossover settings
* Hifonics New Illuminated Heat-Sink Design With Blue LED Light Pumps
* Hifonics Blue Illuminated Logo
* Maxxsonics Illuminated "M" End Panel Logo
* Heavy-Duty Ultra-Fi™ MOSFETS
* Highly Efficient Super D-Class Amplifier Circuitry With Oversized MOSFET Output
* Fully Adjustable Accu-Cross™ Crossovers
* ±18dB Variable Bass Equalization @ 45Hz
* 180° Variable Phase Control (15 to 35Hz)
* Dash-Mountable Bass Remote Control Included
* Variable 24dB Subsonic Filter
* Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
* Twin-Turbo Torroid Coil Design
* HSMD Hifonics Surface Mount Design
* Balance Line Inputs for our 18-Volt Line Drivers
* RCA Line Output for Amplifier Daisy Chaining
* Gold 4-Gauge Power Connectors
* Dimensions: 11.41"L x 10.39"W x 2.63"H
This is the amp i'm wanting and i know you from 3.8.
If I didn't just pick up an alpine headunit, I don't know which one (i think 9887), i'd buy this from you instead of getting it off ebay. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
NoPh33rRaCiNg
NoPh33rRaCiNg
Kent, WA
Donks
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
