FS/FT Shocker Sig 12" Ti frame, aluminum cone D1.4 copper
hispls
'05 (small gap) sig.
Brand new blue TC Sounds Ti frame with rubber gasket.
Prototype Aluminum cone I picked up in trade
Dual 1.4 ohm copper coil (pricision econowind)
Prototype Shocker plastic dustcap (Mike opted for an inverted cap on his newest parts, but I like the look of this one on this cone)
Dual spaced OEM TC Sounds spiders woven-in leads on the top one.
Models a good flat response in 2 to 2.25 cube tuned @ 30 (what I was going for with the heavy cone and soft 10" spiders). Also should deliver a nasty peak up high if you throw it in 3 cube tuned in the high 40's to mid 50's. I'm really impressed with the specs. Wish I had a line on more of these cones and Ti frames...I'd probably make up 3 or 4 for my personal.
TS Specs:
* f(s)= 32.97 Hz
* R(e)= 2.63 Ohms
* Z(max)= 20.68 Ohms
* Q(ms)= 3.354
* Q(es)= 0.488
* Q(ts)= 0.426
* V(as)= 30.540 liters (1.079 cubic feet)
* L(e)= 2.80 mH
* n(0)= 0.21 %
* SPL= 85.40 1W/1m
* M(ms)= 402.80 grams
* C(ms)= 0.06 mm/N
* BL= 21.19
Fresh recone,. I'm going to play it for a couple days to make sure it's tight.
475+ shipping (around 100$). Would consider trades.... preferably stuff that would take up less space! If it's subs it would have to be something pretty special or just raw parts. Good luck even finding a cone like this. I came out of pocket a lot for the frame, 10" spiders, spacer, and cone.
You pick up or pay shipping.
will the tight gap sigs take 8 layer coils?
Not in a million years. In fact there aren't many 4 layers that are narrow enough to fit.
Also I broke this sub last week. ******* sewn in tinsel leads smoked (of course I suspect if I wasn't running 6KW to it they might have survived). Quite a shame, this thing was putting in work
hispls
hispls
Central Maine
hispls
