Sold FS/FT:Pioneer screens, Kenwood,Autotek,Memphis, etc!!!!
Bad95gt
I have the following items for sale or trade:
Pioneer avh p6500dvd...all wires,cables,remote & hideaway unit is included.
$525 ***OBO***
Pioneer avh-p7480dvd w/ avm 9000R master unit...all cables,wires, manual, remote, etc....$520 OBO
Autotek ss 750.1(mono amp), has a few scratches, nothing major or really noticeable - $135 + shipping OBO
3- earthquake tre 10's...svc 800watts max, 300 watts rms - $125 for all 3
Kenwood kvt 911dvd w/ hideaway unit...MINT shape...all cable, harness, remote, etc...PERFECT SHAPE!!!...will get pics up asap of this unit.
$545 OBO!!!.................(pending trade deal)
Tsuanmi 1.0 farad cap w/ digital volt display - $70 OBO
Memphis tweeters w/ crossovers - $30 FIRM
Everything is in excellent condition & perfect working condition...
Items I am looking for/ possible trade:
PS3
X-box 360
42" or larger flat panel hdtv
Concept amps...1200.1252,2400,2410,.....another concept amp for highs & mids
4-channel amps...NO JUNK
JL audio amps...
PPI power class amps
Orion amps (concept 97.3, xtr100d or 1200d, hcca 2100)
2- 12's...NO JUNK
here are some pics:
Pioneer 7480dvd
Kenwood 911dvd
memphis tweeters
3-earthquake 10's
tsunami cap
autotek amp
pic of amp,subs,cap & power/ground wire
$525 ***OBO***
Pioneer avx-p7480dvd w/ avm 9000R master unit...all cables,wires, manual, remote, etc....$500 OBO
what are the differences? i'll ask you since you've used both. which one has a faster UI?
first, there are several differences:
the avh 6500 is a 6.5" touch panel display
the avh 7480 is a 7" Widescreen TFT Active Matrix LCD Color Screen
maybe this will help you more than me;
here are the specs from pioneer
avh p6500dvd:
Display
Screen Size/Aspect Ratio 6.5 inch/16:9
Pixels 1,440x234
Touch Panel
Anti-Glare Screen Coating AGLR
Graphical User Interface Standard OSD
Background Picture 1 Static + 1 Motion
Dimmer Control Intelligent
Picture Adjustment Brightness, Contrast, Color, Hue, Dimmer Settings
5 Selectable Viewing Modes
Motorized Display Open/Close
Selectable Angle Setting 50 ~ 110 degrees
Automatic Display Positioning
Set Back Mode
Half Close Setting
10 Character Sub Display
DVD/CD Player
DVD Video Playback DVD/DVD-R/-RW
CD Playback CD/CD-R/-RW/Video-CD
Compressed Audio MP3 (CD)
ID3 Tag / WMA Text X
CD-Text X
Auto Scroll
CD Track List X (CD Text Only)
MP3/WMA Track List
Sampling Frequency 44.1/48/96kHz
Quantization Bits 16/20/24-bit:Linear
Frequency Response 5-44,000Hz at 96khz
Signal-to-Noise Ratio 97db (1kHz)
Dynamic Range 95db (1kHz)
Distortion 0.008% (1kHz)
Number of Channels 2ch
TV Tuner
TV Tuner Optional GEX-P6400TV
AM/FM Tuner
Supertuner Supertuner IIID
24-Station/6-Button (18FM/6FM) Presets
BSM (Best Stations Memory)
Receiver Features
IP-Bus System Control
XM Satellite Ready
Multi-CD Control
DVD Control X
Auxiliary Input CD-RB10 or CD-RB20 required
External Unit Control 2
RGB Input
AV-Bus Input
Composite A/V Input 1 (AV1)
Back-Up Camera Input
Composite A/V Output 1 (Rear Out)
Dual Zone Audio/Video Front/Rear
Independent Rear A/V Source Control DVD-V
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Equalizer EEQ (3-Band Parametric)
SFEQ (Sound Focus EQ)
EQ-EX
Loudness 3 Mode
Source Level Adjuster (SLA)
High-Pass Crossover (HPF) 50/80/125Hz, -12dB/Oct.
Subwoofer Crossover (LPF) 50/80/125Hz, -18dB/Oct., +/-12dB
RCA Preouts 3 pair (Front, Rear, Sub)
Preout Voltage Hi-Volt (4V), 100 Ohm
Multi-Channel Audio
Multi-Channel Processor Optional DEQ-P7000
Linear PCM/Dolby Digital 2ch
Optical Output
DA (Digital-to-Analog) Converter Standard DAC
Operation Amp Standard AMP
Electrolytic Capacitor Standard
General
Detachable Face Security
Remote Control DVD Control Card
Rotary Volume Control
Dimensions (Main Chassis) 7" x 2" x 6-1/2"
Optional Off-Set Installation Kit AD-GA10
Dimensions (Hideaway Unit) 6" x 1-1/16" x 4-1/4"
specs or the avh p7480dvd:
7" Widescreen In-Dash Fully Motorized TFT Active Matrix LCD Color Display with DVD Player & A/V Receiver
DVD Player Features:
Ultra-Slim Built-in DVD, Video CD/CDPlayer
DVD-R/RW & CD-R/RW Compatible
96kHz/24-bit D/A Converter
DVD Video Output for Rear Display
Optical Digital Output (Dolby®Digital/DTS™/ Dolby Pro Logic/Linear PCM)
LCD Display Features:
Fully Motorized Unit with Display Angle Adjustment
RGB Input (20 Pin) for optional Navigation System (AVIC-9DVD) (CD-RGB26P required for AVIC-90DVD)
AV-Bus Input
Auto Dimmer Control
AGLR (Anti-Glare, Low-Reflection) Coated LCD Color Screen
Detachable Face Security™ with Theft-Deterrent Flashing LED
A/V Receiver Features:
MOSFET45 (45 W x 4-Channel High Power)
Two-Way Crossover
Front/Rear HPF & Subwoofer LPF
Sub-Out Level and Phase Control
XM Satellite Radio Ready
EEQ Performance Chip
3-band Parametric Equalizer
Easy EQ (EEQ) Switches 5 Factory, 1 User EQ Preset
Selectable Loudness Control
Selectable FIE (Front Image Enhancer)
Pioneer Virtual Graphic User Interface (GUI)
Supertuner®III™
A/V Inputs & Outputs
RCA Audio Preouts x3 pair (Front, Rear + Subwoofer)
specs on the avm 9000r master unit:
Features:
5.1-Channel Multi Sound Reproduction Capability
Built-in Dolby Digital (AC-3)/DTS/Dolby Pro Logic Decoder
6-Channel DAC & 6-Channel DSP
New Digital Sound Field Control (SFC) for Multi-Channel Sources (Musical/Drama/Action/5D Theater)
MOSFET45 (45Wx6-Channel High Power)
Optimum Sound Reproduction for Car Environment
New Rear Positions
Cabin-EQ (Sedan/Wagon/Mini-Van/SUV/Custom/Off)
Cabin-EQ Expert (P-EQ/Time Alignment/Level)
Optimum Downmix for Normal Speaker Layout
EEQ™ Performance Chip
3-Band Parametric Equalizer
Easy EQ (EEQ™) Switches 5 Factory, 1 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom)
Selectable Loudness Control (Low/Mid/High/Off)
Pioneer Virtual Theater Graphical User Interface (GUI)
Easy Control & Confirm in Full-Color Virtual-Reality World Graphics
Spectrum Analyzer & Level Indicator
Supertuner III™
24-Station/6-Button (18 FM/6AM) Presets
IP-Bus System Control:
6 & 12 Multi-CD Players
Component Single-CD or –MD Players
DVD Player
TV Tuner (GEX-P7000TV)
Voice Commander (CD-VC50 & CD-VC60)
AV Inputs & Outputs
6 RCA Preouts (FR+FL+RR+RL+Center+Subwoofer)
Optical Digital Input for AC-3/DTS/Linear PCM
RGB Output for Front Display or Optional TV Tuner
Video Source Output(RCA-type, NTSC Video & L +R Audio) for Rear Display
Video Source Output(RCA-type, NTSC Video & L +R Audio) for Add-on Game Consoles, VCR’s and Others
Video Input for DVD (NTSC Video)
Audio/Video Independent Selector for Front Display
Independent Video Selector for Rear Display
both can play DVDs while in drive right?
and i'm leaning more towards the AVH p7480dvd. willing to go any lower at all?
..and just b/c i'm new on here doesn't mean i can't provide many sources of reputation. just wanted to let you know that, too.
thanks
yes...as long as you have the emergency brake bypass......I may have one of them, but it is used....
pretty firm on the price for now........
i see you still bumping your stuff guess we have no deal then? thats shady...
Hmmm...please explain?
You said to ship everything first....I pretty much said no on that......so just curious, what's shady about that?
No different than, when I emailed you & you were saying lets do it & your were still bumping your stuff....//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Bad95gt
Bad95gt
TX/AR
Bad95gt
