Sold FS///FT Lanzar OPTI2000D
Mattd0344
I have a Lanzar OPTI2000D that is in great cosmetic condition but is blown. From looking at the board, it is very clean. At the bottom of the pic where the clips are, you can see what's blown. I has a few light scratches on top but there aren't too many because the metal is pretty tough stuff. On the bottom there are a bit of small scratches but noone will ever see them. Lastly, on the corner of one side of the amp, the bottom plate is bent down about 2-3mm which can be hammered with a rubber mallet and straighten out. This is most likely an easy fix but I'm not 100% on that, I'm just going off of how clean it the board looks and nothing major looks damaged. I just traded 6 Lanzar OPTI1000.1D's and all were repairable.
$180 Shipped
MSRP:$722.20
.5 ohm stable!!
Here are some specs:
  • 700 Watts RMS Power @ 4 Ohms
  • 1100 Watts RMS Power @ 2 Ohms
  • 1600 Watts RMS Power @ 1.3 Ohms
  • 2000 Watts Max Power @ 0.5 Ohms
  • 4000 Watts Bridge Max Power @ 2 Ohms
  • Mono Block Subwoofer Amplifier
  • 0.5 Ohm Stable
  • MOSFET Power Supply
  • PWM (Pulse-Width-Modulated) System
  • Double Sided Epoxy PCB Circuit Board
  • Gold Plated RCA Inputs
  • Custom Terminal Block for Speaker Connections
  • Thermal, Overload Short Protection
  • Remote Bass Control
  • Soft Turn On/Off
  • THD @ 1Watt/4 Ohm: 0.1%
  • S/N Ratio: 90dB
  • Frequency Response: 15Hz - 150Hz (+/-3dB)
  • Damping Factor @ 20Hz/4 Ohms: 400
  • Low Pass Filter: 50Hz-150Hz, 24dB/Octave
  • Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
  • Variable Bass Boost: 0 to 18dB
  • Variable Phase Control: 0 to 180
  • Input Sensitivity: 200mV ~ 8V
  • Input Impedance: 10k Ohm
  • Line Output Impedance: 100 Ohm
  • Fuse Rating: 30A x 6
  • Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
Mattd0344
Mattd0344
Colorado
Mattd0344
