Never seein power.
Audio Pulse Axis 15. It will be shipped on its original crate.
http://www.audiopulse.com/products/subwoofer-drivers/axis
400 SHIPPED!
Trades are welcome.
Parameters
Qts 0.33 0.40
Re (series) 4.7 Ω 4.7 Ω
Fs 25 Hz 22 Hz
Cms 125 µM/N 135 µM/N
Vas 44 lit 126 lit
Mms 310 g 390 g
BL (series) 26.2 Tm 26.2 Tm
Sd 0.050 m² 0.082 m²
SPL 85.2 dB 87.4 dB
Specifications
Voice Coil Configuration D2 | Q1 Ω D2 | Q1 Ω
Mounting Depth 7.99″ 9.48″
Driver Cutout Diameter 11.16″ 14.02″
Overall Driver Diameter 12.60″ 15.51″
Magnet Weight 225 oz 225 oz
Driver Weight 44 lbs 46 lbs
Performance
BL²/Re 140 N²/W 140 N²/W
Xmax 30 mm 30 mm
TLS:
Recommended Amplification 2500 W RMS 2500 W RMS
4th order
reflex enclosure volume 1.2 - 2.1 ft³ 3.0 - 4.2 ft³
2nd order sealed enclosure volume 0.6 - 1.4 ft³ 2.0 - 3.8 ft³
Pictures.
400 SHIPPED!
Trades are welcome.
Parameters
Qts 0.33 0.40
Fs 25 Hz 22 Hz
Vas 44 lit 126 lit
Mms 310 g 390 g
SPL 85.2 dB 87.4 dB
Specifications
Performance
Xmax 30 mm 30 mm
TLS:
4th order
Pictures.
