Sold FS: Fiberglass Boxes for 93, 94, 95, 96 Camry
GCAdidas13
heh.
Fiberglass Boxes for 93, 94, 95, 96 Camry - Price: $Negotiable Plus Shipping
The second picture is for the driver side and the third picture is for the passenger side. The white residue is from a double-sided tape I used to affix the tweeters while in home theater use. They probably will need sanded and painted. I can sand and re-paint them black if you would like (at additional costs).
The boxes pictured are approximately 0.15 to 0.20 cubes. They fit most, if not all 6.5" drivers, however if needed I can get a cutout diameter for you.
Also for sale, but not pictured, is a pair of boxes that would mount to the door. These boxes are for 8" drivers and are approximately 0.25 to 0.30 cubes. They do not need refinished. However I should say that if you were to wish to install these door pods you will have to cut your door panels to fit.
PM me if you are interested, or email me at GCAdidas13(at)columbus{dot}rr[dot]com
Brian
Yes. These are a bit older. They were before I added the little bit at the top to hide the wires. From a normal person's eyes view, the added fiberglass hides all of the wires that you can see in these two pictures.
When I get back to school I will compare my 92 to the pics. Did you have UP6's in there? I think that's what I remember. I was going to try to seal up my doors a little better to improve midbass and get rid of some rattles, but it hasn't been above freezing for such a long time and I don't have a garage at school. Might be a good alternative. Can you tell me what kind of mounting depth these can handle? I believe the R6a's have a higher depth than the UP6's (not sure).
edit...I just checked and the DLS website reccomends 10-12 liters for the R6a's, which is about .35 cubic feet minimum if my calculations are correct...
Your calculations are correct, and no, i had UR6's in there. Both of the boxes fit UR6 and the CDT HD6 component mid.
When I fiberglassed the boxes I had visualized them being much bigger than they actually are. After further inspection, I realize that there is no way that I could fit 5 or 6 2-liters of water in these boxes. I would guess somewhere between 2 and 3 2-liters would fit in each one.
And for some reason the UR6s sounded really good in the boxes anyway //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
email me with a price to get them looking real real spiffy... tanto420 @ stny . rr. com i may also be interested in the alt.. not sure yet... we'll talk =)
GCAdidas13
heh.
GCAdidas13
Grove City, OH
Tanto420
