SOLD FS: Exodus Audio Tempest-X 15" Subwoofer NIB SoCal pickup only!
  • 4
Aaron909
I have a BRAND NEW, STILL IN BOX Exodus Audio Tempest-X 15" Subwoofer for sale. I had bought 2 but realizes that 1 is more than enough. Pics will be uploaded later today when I get my camera. Price is firm $175 SoCal pickup only. Located in Diamond Bar, CA
Here are some details about the sub:
SPECIFICATIONS
* Fs: 18.5 Hz
* Le: 0.90mH
* Re: 3.65 Ohms (Voice Coils wired in parallel)
* Qms: 3.4
* Qes: .60
* Qts: 0.51
* Mms: 200g
* Cms: 0.37 mm/N
* Vas: 324L
* Sd: 791 cm^2
* Vd: 4.27L
* BL: 11.86
* X-max: 27mm
* Pmax: 600W
* SPL: 87.2 db/1W/1M
FEATURES
* Ultra low distortion XBL^2 motor optimized for low inductance & flat BL curve.
* 15" Driver Optimal for a wide range of applications, ported, sealed & infinite baffle. See product documentation for details.
* Massive amounts of linear excursion (27mm x-max one-way) for high output and low distortion.
* Extremely high quality parts selection. Excellent build quality and design by one of the world's experts on low frequency transducer design.
* Dual 8 Ohm Voice Coil arrangement for multiple hook-up arrangements.
* Spring loaded terminals for easy hookup.
http://www.diycable.com/main/product_info.php?cPath=24_93&products_id=652&Cid=ea00923c9b3e6a2396b239399fead024
Edit: Pics
trade for an Alpine cda-9833 or a CDA-7897? both 3 way active capable. I also have some Vifa xt25 tweets...
Thanks, but I'm looking to get something non car audio related. I should have said that first. Something like a Wii, or any other electronic device around the subs price range.
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
173
Aaron909
Aaron909
Los Angeles, CA
tc3k101
    May 31, 2024
    May 24, 2024
