FS: elemental designs NINe.5
c_b_
Item(s) for Sale: ed NINe.5
Bought this used and it has been great to me. Just sold my suv and no need for this right now. The amp is in great shape and I have never had any problems with it. 2 minor scratch areas shown in the photos were there when I bought the amp.
RMS Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
RMS Power (Subwoofer Channel) @ 12.5v :
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
$350 shipped and insured. Not interested in trades. Not desperate to let this go. If it doesn't sell for value then I'll hold on to it for some time. I'd like to have it with someone who needs it but I don't need to give it away.
I'll choose unless buyer wants something specific.
Additional Info per Elemental Designs:
0Awg Capable:Such a beast of amplifier requires a beast of a connection. The NINe.5 amplifier comes out of the boxready to fit wire as large as 0/1 eNETIC cable.
2 Stage Protection Circuit:The NINe.5 protection circuit design is unique in it’s integration isolating the front and rear channels independently from one another. If your driving one part of the amplifier too hard it’s active communication system protects the entire amplifier. The front 4 channels and 5th subwoofer channel are independently protected.
3 Level Inputs:Individual inputs for 3 channels are integrated into the NINe.5 amplifier. 2 front channels and the independent subwoofer channel.
Adaptive Input: The NINe.5 input section allows you to use inputs from 1 channel or 3 channels selectable externally right on the amplifier.
Dedicated Subwoofer Channel Crossover:The subwoofer crossover section ranges from 40Hz - 100hz @ 18dB w/ very simple toggle On/Off switch allowing you to use the onboard crossover or digital X/O from your head unit.
Easy Connections:The NINe.5 features very simple connections on all channels. Fully housed connections protect one another while increasing speed and reliability of installation.
HP/LP/BP Crossovers Included:The NINe.5 features a unique crossover to it's design. Full Low Pass / High Pass / Bandpass capability on all 4 front channels @ a 18dB slope. Ranging from 50Hz to 4KHz it gives you a fantastic range of control for the most demanding systems.
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
c_b_
c_b_
bluegrass st
c_b_
    May 12, 2024
Brendon Jenness
    May 11, 2024
