Sold FS: Eclipse Audio stuff
metpage
Anyone want the following audio equipment:
Eclipse 8122 12" DVC subs x2 = $200/pair or $150/each(new in box)
Eclipse 8264 6.5" components = $100(new in box)
Eclipse 6213 2 Channel Amp = $300 (new in box)
Eclipse 3320 2 Channel Amp = $50 (used, no box)
Eclipse ESG-8220 Center Speaker = make offer (used)
Gathers Indash Screen = $200 (from a JDM 5th Gen Accord)
Need cash to pay off some debts, i accept paypal!
PRICES DO NOT INCLUDE SHIPPING
pics of everything!:
Pictures can be found here: http://www.accordinglydone.com/forum/showthread.php?t=13073
Specs:
8122 DVC Subs:
-Santoprene Surround
-Aluminum Cone
-Dual Mirror-Image Spiders
-Aluminum Voice Coil Former
-"Bottomless" Design
-Aero-Vented Pole Piece
-Cast Aluminum Frame
-Double-Stacked Magnet
-Small Sealed-Box Enclosure
-Continuous Power Handling: 500W
-Music Power Handling: 1,000W
-New Dual Voice Coil (SW8122DVC)
-QCA (Quick Change Assembly)
DA6213 Amp:
-Maximum power output of 500W (both channels) into a 2 load
-Fully bridgeable operation with 1100W (single channel) into a 4 load
-Class D full-range, full bandwidth operation
-Low RFI emission rate does not impact radio performance
-Flexible, multi-application use from full-range speaker systems to midbass and subwoofer applications
-ChannelFlex Crossover
-Lo-Pass (12dB/oct., 50 — 200Hz)
-Defeatable Subsonic (18dB/oct., 20 — 60Hz)
-Pre-Amp Output Hi-Pass (12dB/oct., 50 — 200Hz)
-Robust MOSFET spread spectrum switching output section
-Proprietary MOSFET Pulse Width Modulated
-switching power supply
-Amplifier and speaker protection
-Cool running even during protracted heavy use
EA33230 Amp:
-2 channel amp.
-130 X 2 into 4 ohms
-400 X 1 into 4 ohms.
-It will not handle lower than 4 Ohms, bridged
SC8362 Components:
-Size 6.5"
-Nominal Power Handling 100 Watt
-Peak Power Handling 200 Watt
-Frequency Response 50 Hz - 22 kHz
-Sensitivity 12 dB
-Tweeter Size 1 "
-Magnet Material Neodymium
-Surround Material Rubber
-Top Mounting Depth 2.88 In.
-Bottom Mounting Depth 2.88 In.
ESG-8220 Center Speaker:
-Size: 7.85" x 2.5" x 2.3"
-RMS Wattage: 20
Above items are still for sale, buy my stuff people!
UPDATE:
Eclipse 8122 12" DVC subs x2 = SOLD
Eclipse 8264 6.5" components = SOLD
metpage
metpage
Wheaton, MD
metpage
