Sold FS: DLS A6 Amplifier
nofriends46
Selling my DLS A6
7/10 Cosmetic
One of the speaker terminal output, the screw is jam in. Can be taken out carefully, but i didn't wanna bother. Because this amp comes with 2 pair of speaker terminal outputs, more flexible for installation.
10/10 Functional
Number of channels 1
Amplifier class AB
Output power in 4 ohm 500 W
Output power in 2 ohm 870 W
Mono bridge mode 4 ohm N/A
Output power in 1 ohm 1200 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Input impedance, high level N/A
Input impedance > 10 kohm
High pass filter Subsonic: 25 Hz
Low pass filter 50-125 Hz
External cooling fan terminal 1
Dual DC inputs 1
Phase control for subwoofers 0- 180 grader kont. variabel
Remote base level control 1
Remote phase shift control 1
Integrated fan 1
Power consumption (idle) 0,6 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 35 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Note: Picture is with a Iphone, can't find my digital camera at this time.
$250 + Shipping
I will also include the stinger fan, incase you hook this up at 1ohm.
Best bet is to email me directly to nofriends46@yahoo.com
nofriends46
nofriends46
Hawaii, Kauai
jamesdean
