Fs) Digital Designs Speakers for sale! German sets, t2s, midbasses; MUST SEE VIDEO!!!
cdimic25
DD t2 tweeters
DD german 6.5s one set used one set new
DD 6.5" midbass
DD t2's new:
Specifications
Cutout Diameter 1.95"
Diaphragm Material Ultralight silk
Frequency Response 2kHz-30kHz
FS 1580 Hz
Magnet neo
Mounting Depth (in.) 0.70"
Sensitivity 91 dB
Voice Coil Diameter 26mm
DD at28 tweeter (german)
The DD-AT28 is a wide-band tweeter with a 28mm coil diameter. It uses two rear chambers, one behind the voice coil and a second milled aluminum chamber behind the motor. Shorting rings are used in the motor to flatten the impedance curve and wick away heat from the coil windings. The proprietary fabric dome has a range extending 10,000Hz past the hearing capability of the human ear. Countless hours of listening have been done to "tune" this tweeter via each part, glue joint and assembly step. The result is a most listenable tweeter which will show you new details you hadn't known possible.
Specifications
Frequency Response 1500 Hz to 30 kHz
FS 800 Hz
Nominal Impedance 4 Ohm
Power Handling 120 W RMS
SPL 1W, 1m 91dB
Voice Coil Diameter 28mm
DD aw6.5 (german)
The DD-AW6.5 mid-woofers represent "state of the art" in driver technology. The machined motor structures with the distortion reducing effects of Faraday Rings are held to the tightest tolerances and provide a well damped magnetic field for the voice coil. The suspension was optimized for sharp mid-bass and controlled sub-bass. The coil wire is the highest temperature available and held with the finest adhesives. The coil former is ventilated and the wire gauge/former thickness optimized to reduce moving mass. The adhesives from the coil to cone are bonded with specialized, hardened material to pass all energy from the coil to the cone. The cone is made from lightweight aluminum to achieve wide bandwidth and efficient energy transfer to the air.
DDA components include all the dizzying aray of technology one finds in the upper echelon of the worlds finest drivers along with precision German assembly and attention to detail. The result is crisp, clear and detailed sound with forceful bottom end.
Specifications
BL 5.55
CMS 0.33mm/N
Frequency Response 50Hz - 14kHz
FS 66.01 Hz
Magnet Weight 12 oz
Moving Mass 17.48g
Power Handling 120/480 W RMS
QES 0.80
QTS 0.68
QMS 4.36
SPL 1W, 1m 90.5dB
Suspension Travel 25mm
VAS 8.5 l
Voice Coil Diameter 37mm
Woofer Diameter 6.5" 165mm
DD 6.5 from component sets
The DD Audio CS components are high tech, high fidelity speakers designed to fit the tight confines of complex door panels. It is no longer neccessary to sacrifice sound quality in a shallow cavity OEM application.
Our focus on sound quality starts with precision motor assemblies. The machined magnet gaps driven with high energy strontium magnets provide strong output from a compact design. We incorporate distortion reducing shorting rings for flux modulation and inductance control.
The midwoofer cones are rigid pulp with acoustic treatment applied to the front, reducing cone break up while providing water/humidity resistance. The compressed rubber surrounds are optimized for light weight to increase sensitivity.
Specifications
Crossover Frequency 4kHz - 12 dB/Oct
Cutout Diameter 5.65"
Frequency Response 40Hz - 25kHz
Mounting Depth (in.) 1.93"
Power Handling 60 RMS, 100 Music, 200 Peak
Sensitivity 91 dB
Shipping Weight 6 lbs
Tweeter Coil Diameter 25mm
Woofer Diameter 6.5 in
T2- 50 shipped
DD at28- 220 shipped for pair of new; 190 for used
DD aw6.5-220 shipped for pair of new; 190 for used
DD 6.5- 70 shipped for pair
I support the USPS during their hard times, everything will be shipped through them and is included in prices.
im a fan of videos, so heres a video BE SURE AND WATCH IN HD!
http://www.youtube.com/watch?v=51TuA18urzw&feature=plcp
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
665
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
cdimic25
cdimic25
mbxrb
    May 16, 2024
    May 16, 2024
