Sold FS: Digital Designs S4
jblayz1
I went back to passive and no longer need this amp. used for less than 2 months. $365 shipped. looks 9/10(mounting tabs are scratched), function 10/10. i will post pics when i get home.
Specs-
Series
S
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Subsonic Filter
Variable Low Pass Filter
50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model S4
Power at 4 ohm
100W x 2ch + 200W x 2ch
Power at 2 ohm
150W x 2ch + 300W x 2ch
Damping Factor >550 @ 2 ohm
Power at 1 ohm
175W x 2ch + 350W x 2ch
Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Power at 3 ohm Mono 350W x 1ch + 700W x 1ch
Max Dynamic Power
400W x 1ch + 800W x 1ch
Efficiency thru Output
64%
Dimensions - mm
390 L x 235 W x 53.4 H
Dimensions - inches
15.35 L x 9.25 W x 2.1 H
Signal to Noise 95 dB
Shipping Weight
16 lbs
pics
jblayz1
jblayz1
Miami, FL.
jblayz1
