For Sale!!! Digital Design Z1 I had purchased it New from dave(louisiana_CRX) about a month ago. I have used it for 3 weeks and decided to redesign my stereo eqipment setup for a new suv that I am getting.
It is in perfect condition
$1050 Shipped //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif (within the US)
The marks on the amp are just fingerprints
Series
Z
Input Sensitivity
0.2V - 8V
Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter
35 Hz - 250 Hz at 24dB/Oct
Clipping Display
LED
Signal to Noise
85 dB
Damping Factor
Tested Voltage
14.4V
Tested THD
1%
Model
Z1
Power at 1 ohm
3000W x 1ch
Max Dynamic Power
Warp Factor 5
Efficiency thru Output
Dimensions - mm
610 L x 304 W x 70 H
Dimensions - inches
24 L x 12 W x 2.76 H
Shipping Weight
35 lbs
Originally Posted by PsychoTheRapist
Bench tested by Peter.T from Soundpressure.com (Sweden):
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
Series
Z
Input Sensitivity
0.2V - 8V
Subsonic Filter
Clipping Display
LED
Signal to Noise
85 dB
Damping Factor
Tested Voltage
14.4V
Tested THD
1%
Model
Z1
Power at 1 ohm
3000W x 1ch
Max Dynamic Power
Warp Factor 5
Dimensions - mm
Dimensions - inches
Shipping Weight
35 lbs
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
