SOLD FS: Diamond Audio Hex Tweeters
whitedragon551
Moderator
14,193
79
IL
I have a pair of Diamond Audio Hex Tweets out of the D661v1 component setup. They come in either a silk or aluminum tweeter. These are the aluminum version.
Id give them 10/10 mechanical and an 8-9/10 physical. One of them has a small dent in the mesh grill on one of them. Its completely cosmetic and barely noticeable until up close.
Price: $45 shipped/OBO All reasonable offers will be considered.
*NOTE:* These are not the Diamond Audio D1T tweets that go for $40 new.
Any lowballs beyond this point will be ignored. Just to clarify I WILL NOT take $25 for the pair. They are worth more than what Im selling them for as is.
OBO stands for or best offer. Do not get offended when someone makes you an offer. If their offer is too low consider a counteroffer before replying in a smartass manner. I would've probably given you $35 or $40 for them...it was just an initial offer.
But as you indicated previously, just "toss them" if you don't get your asking price.
This wasnt even aimed at you. Thanks for the bump.
Bump for pics of the mounts. Apparently the donuts that go on the back break on alot of these Diamond Tweets. These ones are still in one piece. Ive got these ones and the surface mounts that are in the pictures on the first page. Ive also got the manual for the entire comp set in the garage.
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
Now coming out to the wholesale distributor, Sub sonic car audio new brand owned by selelectronics since 2000. Look for new subs ,amp, empty...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
216
whitedragon551
Moderator
whitedragon551
IL
chief_bignut
maylar
    Jun 2, 2024
    Jun 1, 2024
