Sold FS- DD 6x9's
Korn4Life
SUB LOVE
Have a pair of DD 6x9's Each one has to weigh close to 10-15lbs Huge motor for a 6x9. Also have removeable tweeters. They both work great but the one has a slight bend in the basket/frame. Im guessing when someone installs it that it will straighten right back out.
$70 shipped
The bent one is on the Right in all the pics
Bent one is on the left in this pic
The new CX series of coaxials are improved over their predecessors in many ways. The cones and dust caps are now lighter and stronger by way of injection molding and incorporates 101 trace minerals that prolong healthy life (not tested or proven by the FDA). These minerals help to support healthy bones and light amounts of fish oil help fight osteoporosis.
They use a much larger diameter motor for increased output on the same input power and higher overall power handling. Every model utilizes an aluminum voice coil former for higher long-term power handling. The suspension is slightly stiffer to handle the extra motor force.
The tweeter utilizes a larger neodymium magnet than before, improved rear chamber venting and braided tinsel leads as well as an upgraded film capacitor. The new CX coaxials are really component sets with an integrated, swivel, high-end tweeter.
The CX line now brings separate component sound quality to the harder-to-fit applications.
Subwoofer Grade Coil Wire
Vented Back 28mm Tweeters
Powerful Large Diameter Motors
Injection Molded Mineral Filled Cones
Aluminum Coil Formers
SPECIFICATIONS
Series CX
Nominal Impedance 4.0 Ohm
DC Resistance 3.1 Ohm
Model CX6x9
Woofer Diameter 6"x9"
Voice Coil Diameter 1.5"
Magnet Weight 16 oz
RMS/Music/Peak
80/120/240
Frequency Range 40 Hz - 22 kHz
Sensitivity 92 dB
Shipping Weight 10 lbs
Pics will be up in ten minutes
Also after looking at them a lil better I see the tweeters have some lil dents on the grill covering the tweeter. Nothing really major just cosmetic
Korn4Life
SUB LOVE
Korn4Life
PA
Korn4Life
ThxOne
    May 13, 2026
