Sold FS: Computer parts, Mobo, Processor, Heatsink
Moe Lester
1/3 of TEAM PWNAGE
AMD Athlon XP 2500+ Barton asking $60 shipped
it will run 2.3 ghz @ 1.725 volts all day long without any problems. With enough voltage and proper cooling 2.5ghz is achievable. Ive benchmarked this chip running @ 2507 mhz and it seemed to be stable. It was only run at this speed for a few tests though.
Epox 8RDA3+ Nforce 2 Ultra 400 Mobo asking $65 shipped
Ive run this board at 217mhz FSB daily, and have taken it up to 230mhz but was limited by my RAM. Back when it first came out, it was beating out the Abit NF7-S OC wise. Its capable of dual channel DDR. AGP 8X, has 4 USB 2.0 ports on the back, dual 10/100 RJ45 ports and 5 channel audio.
Thermalright SLK-900 Socket A heatsink, asking $25 shipped. This is a VERY good heatsink and is capable of cooling any socket A processor out there. No fan is included though. It can hold a 92mm, 80mm, 70mm, or 60mm fan. Ive only got the 92mm and 70mm clips. You could easily bend the 92mm to fit an 80 or the 70mm to fit a 60 no problem. Ive also got a full tube of the thermalright TIM that came with my SP-90C that im going to include with it. I re-finished the bottom with 1500 grit sandpaper and put on new pads to protect the processor. The fins will get cleaned off better before i send it.
If you want it all, ill let it go for $140 shipped.
Id recommend at least 300 watts if you are gonna run it stock speeds. If you plan on overclocking it and running it that way id suggest a quality 400w or higher PSU. It requires a 20pin standard ATX conector and a 4 pin P4 connector.
what kinda power supply does it require wattage wise im interested but need to see what my bills are after this weekend first.
one of my puters is a XP 2500+ with an SLK800 and I run 2 HDs, DVD/CD-R combo drive and a DVD-R/RW drive off a 350watt PSU no problems at all.
bump for some nice equipment
//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Moe Lester
1/3 of TEAM PWNAGE
Moe Lester
Houston, TX
Moe Lester
