Both are brand new in box, have 2 of the amps and 3 alarms available.
A little about the amps:
Utilized in the power supply circuitry, Gapped E core choke coils offer low impedance, making them resistant to harmful magnetic noise. This results in a more efficient amplifier and a low-noise power supply, which is important when achieving crystal clear sound. Variable High/Low-Pass Crossover Select amplifiers have built-in low-pass and high-pass filters allowing for adjustment in the APA4320/2160: 55Hz to 550Hz, APA4300HX: 50Hz to 200Hz frequency range over all channels. This allows for easy configuration of more complicated sound systems that encompass multiple amplifiers and subwoofers. Clarion’s amplifiers offer increased conductivity and low signal loss. Gold has an extremely low electrical resistance and low contact resistance, which helps prevent voltage drops, noise, heating and other problems from occurring. APA Series amps feature a die-cast design that boasts countless heat sinks for highheat dissipation. This eliminates the need for an internal fan. Also preventing overheating is the amplifier’s circuit design that inhibits heat dispersal. This heat dispersal effect is maximized during consecutive drives for high power in minimal space.
Brand: Clarion
Condition: New
RMS Power Output: 80W x 4 @ 4 Ohm
Peak Power Output: 160W x 4 @ 4 Ohm
Birdged Output: 230W x 2 @ 4 Ohm
Frequency Response: 55Hz-550Hz
Bass Boost: 0~15dB @ 45Hz
Built-In Crossovers: HP LP
Ohm Load Stability: 2 Ohm
Low Level Input: Yes
Built in Cooling Fan: Yes
Maximum Power Output 640W
Continuous Average Power Output 320W (80W x 4 Into 4 Ohms 20Hz-20kHz @ 0.05% THD)
Typical 2-Ohm Stereo 115W x 4 @ 0.2% THD
Typical 2-Ohm Bridged Power 230W x 2 @ 0.2% THD
Bass Extender Control 0~15dB @ 45Hz
Adjustable 55Hz-550Hz, 12dB/oct. High/Low-Pass Crossover
Mixed- Mode Operation
4-, 3-, or 2- Channel Operation
MOSFET Output Design
Speaker Level Inputs
Double-Sided FR4 PC Board
Looking for $140ea
Alarm is made by DEI:
One 2-Way LCD Remote
One 4-Button Remote
3 Auxiliary Outputs
Driver’s Door Priority Capable
Anti-Code Grabbing Technology
Individual Remote Recognition
Remote Enable Valet
Hyper Blue Status LED
Remote Panic
ProSecurity Programmer
ProSecurity Power Up and ProSecurity Starter Disable
Selectable Ignition Controlled Door Locks
Dual Stage Impact Sensor
Extended Range Antenna
Programmable Override Sequence
Remote Silent Arm/Disarm Capability
Event History Diagnostics
Custom Auxiliary Configuration
Remote Sensor Bypass
Selectable Siren Duration
False Alarm Prevention Circuitry
looking for $100 each
Brand: Clarion
Condition: New
Looking for $140ea
One 4-Button Remote
3 Auxiliary Outputs
Remote Enable Valet
Remote Panic
