Sold FS Boston Acoustic Pro60's
ace_800
Picked these up from echo and was told one of the speakers were blown. Tested them, speakers showing 3.2-3.7 ohms, tweeters showing 6.5ohms. Tested the crossovers with the speakers hooked up, showing 3.5ohms. I just installed them to test them out, sound great no problems. The only blemish is one of the crossovers, the tweeter xover, has a crack down the middle. Doesn't effect it. Ran off a PG xenon 200.4, strong, clear sound, no problems. So since I needed only one woofer, there is no reason to split up a good set. So there up for sale, everything is in the set, all the tweeter mounts, everything. So $250 Shipped obo.
Rated RMS Power Handling
125 watts
Nominal Impedance
3 ohm
Frequency Response (±3dB in car)
50Hz-22kHz
Mounting Cutout Diameter
5" (127mm)
Mounting Depth
2-3/8" (60mm)
Mounting Depth with Spacer
2-1/16" (52mm)
System Type
2-way
ace_800
ace_800
Okinawa, Japan
ace_800
