i'll get pics of the other two amps tmw
Specifications
FM TUNER SECTION
Tuning Range ................................................................. 87.7 – 107.9 MHz
Mono Usable Sensitivity ................................. 9.3 dBf (0.8 µV/75 ohms)
50 dB Quieting Sensitivity .................................. 13.5 dBf (1.3 µV/75 ohms)
Alternative Channel Selectivity ......................................................... 80 dB
Signal-to-Noise Ratio ..................................................................... 80 dB
Stereo Separation .......................................................................... 45 dB
AM TUNER SECTION
Tuning Range ............................................................... 530 – 1,710 kHz
Sensitivity (IEC Standard) ................................................ 22.5 µV/27 dB
CD SECTION
Frequency Response........................................... 5 – 20,000 Hz (±1 dB)
Wow & Flutter (% WRMS) ................................ Below measurable limits
Total Harmonic Distortion ........................................... 0.008% (at 1 kHz)
Dynamic Range ............................................................ 95 dB (at 1 kHz)
Signal-to-Noise Ratio ..................................................................... 95 dB
Channel Separation ...................................................... 85 dB (at 1 kHz)
REMOTE CONTROL
Battery Type ........................................................ AAA batteries (2 pcs.)
REMOTE CONTROL SIZE
Width ............................................................................... 56 mm (2-1/4")
Height ............................................................................... 14 mm (9/16")
Depth ............................................................................ 105 mm (4-1/8")
Weight ................................................................................. 50 g (1.8 oz)
GENERAL
Power Requirement ............................... 14.4 V DC (11–16 V allowable)
Maximum Power Output (CDA-7842 only) ............................... 40 W ´ 4
Maximum Pre-Output Voltage .......................................... 4 V/10 k ohms
Bass .................................................................................. ±14 dB/60 Hz
Treble .............................................................................. ±14 dB/10 kHz
Weight ........................................................................ 1.5 kg (3 lbs. 4 oz)
CHASSIS SIZE (W ´ H ´ D) ... 178 mm (7") ´ 50 mm (2") ´ 153 mm (6")
NOSEPIECE SIZE
(W ´ H ´ D) ... 170 mm (6-3/4") ´ 46 mm (1-13/16") ´ 18 mm (11/16")
