FS: Belva BB5000D
Austinw88
Belva BB5000D
BB Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 1200 watts x 1 chan.
2 ohms: 1800 watts x 1 chan.
1 ohm: 3000 watts x 1 chan.
Max power output: 5000 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +12 dB bass boost adjustable between 30-80 Hz)
Preamp RCA outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heat-sink
Input sensitivity:
Low level: 100mV-6mV
Variable low-pass filter (40-180 Hz, 12 dB/octave)
Subsonic filter (12 dB variable from 20Hz - 50 Hz)
Frequency response: 20-30,000 Hz
200-240 Amp in-line fuse required, see our selection of recommended fuse holders
Depending on operating impedance, 1/0 or 4 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier.
Dimensions: 20-3/8"W x 8-1/4"D x 2-1/4"H
Belva BB5000D 3000W RMS BB Series Class D Monoblock Car Amplifier
Great condition but is missing 1 set screw for speaker terminal
I have the og box, manual and bass knob
225 Shipped
on me
The brutus, as long as you stay above 14.4 volts and up, you should get rated/close to rated power after accounting in box/impedance rise. Not sure how beefy your electrical is but I would save up for the quality amps.
It pretty much comes down to how much the amp can do when given X amount of power/amperage. Both choices would probably draw about the same amount of current from your electrical systems but the quality one will put out more power due to increased efficiency from design.
I mean if you can keep voltage drops above 14 volts running 4k rms, then adding another Hifonics would be okay if your really on a budget. There's just a lot more power to be had with higher quality amps IMHO.
when strapping amps if i am going for say the 4800w rms that 2 brutus would put out together both at 1 ohm. does that turn it into 4800w rms at .5 ohm or does it stay 1 ohm? sorry im pretty noob when it comes to most of this stuff.
Whatever your nominal impedence is your amps will each see half of that. For example if you have a 1 ohm nominal load each amp when strapped will see .5 ohms. Not sure if the brutus can handle .5 ohms, i have yet to test that out.
Austinw88
Austinw88
South Carolina
Austinw88
