Sold Fs Audiopulse revo 10 inch d2 cosmetic damage
jadon087
The Snowman
I am selling the Audiopulse revo i brought from cloak and never got to use because i was in a wreck and need cash to pay for it. The sub was in the car with me and was strapped down nicely and did not move, but did receive cosmetic damage to the cone. Which is why im selling it for 200 shipped+pp would be shipped parcel post unless you are close.
Sub move freely and does not make a scratching sound and coils read perfect.
specs
Audiopulse REVO 10Products > Car Audio > Subwoofers
lukas uploaded this photo on February 27, 2008 Average rating:
Your rating:
Please click here to upload an image of the Audiopulse REVO 10.
Design
* Flat-wire technology for excellent conductor packing density
* Long throw high temp 3" wide voice coil
* 10" linear suspension system with large lead wires for improved durability
* Patent pending NBR tall profile FEA surround for excessive travel
* Massive 3.5" conductive shorting ring to improve linearity
* Single dish anodized and powder coated alloy heat sink cone
* Patented field replaceable top assembly system makes "recones" obsolete
* Patented exclusive high excursion frame assembly
* High BL promotes inherent small box design to save space without compromise
* Distinguished metallic clear blue triple layer powder coated frame
Parameters
Qts 0.38
Re 4.6ohm
Fs 28 Hz
Cms 118 µM/N
Vas 17.4 lit
Mms 270 g
BL 23.0 Tm
Sd 0.032 m²
SPL 81.7 dB
Specifications
Voice Coil Configuration D2 ohm
Mounting Depth 7.35"
Driver Cutout Diameter 9.25"
Overall Driver Diameter 10.52"
Magnet Weight 195 oz
Driver Weight 32 lbs
Performance
BL²/Re 115 N²/W
Xmax 28 mm
TLS:
Recommended Amplification 1500 W RMS
4th order reflex enclosure volume 0.8 - 1.5 ft³
2nd order sealed enclosure volume 0.5 - 1.5 ft³
jadon087
The Snowman
jadon087
Columbia,Sc
jadon087
