FS: AudioControl 6XS Electronic Crossover
$LICK CALIFA$
I'd give it a 9/10 cosmetic & 10/10 mechanical - the smudge on the bottom can be wiped off. Doesn't come with the power plug (but still works!) or the bass remote but you can get the plug on ebay for less than $10 shipped.
The manual can be found here... 6XS 6 Channel Electronic Crossover
AudioControl's 6XS 6-channel crossover uses a steep 24 dB per octave slope to separate your high and low frequencies, along with a built-in line driver that'll beef up the signal from an anemic receiver.
The 6XS crossover features front, rear, and subwoofer inputs, along with four sets of outputs: front high-pass, front low-pass, rear high-pass, and subwoofer. It comes preloaded with crossover modules that will work in a number of system configurations, but you can change the crossover point by buying another AudioControl module, or by modifying the modules installed in your 6XS. A built-in filter cleans up extreme subsonics in your signal so your amps and subs will play louder and cleaner.
Features:
6-channel Linkwitz-Riley electronic crossover
white steel chassis with gold-plated RCA jacks
line driver with adjustable output (up to 9 volts)
top-mounted controls for easy adjustment
6-channel inputs (front, rear, sub)
balanced inputs eliminate noise
PFM subsonic filter (18-100 Hz at 18 dB/octave)
frequency response: 10 to 100,000 Hz
signal-to-noise ratio: 110 dB
maximum output level: 9.5 volts (13v peak)
fuse rating: 2 amps
size: 7-1/4"W x 1-1/4"H x 7-3/4"D
8-channel outputs:
front high-pass: 250 Hz and up @ 24db
front low-pass: 90-250 Hz @ 18db
rear high-pass: 250 Hz and up @ 24db
subwoofer: 30-90 Hz @ 24db
subsonic filter: 33 Hz @ 18db
$150 Shipped OBO
Included in price
I was looking at the Manuel and do you have to buy resistors or modules if you want a different frequencys? I been wanting to buy one of these but I don't want to make my own resistors or modules every time I want to change something....
yes, why would you change your crossover points so many times? it's actually really easy to swap.
I wouldn't change it a lot of times, only a few times. LolDoes it comes with the resistors or whatever you need to change it?
The 6XS doesn't include extra resistor networks, but you can find them for less than $1.
The 24dB crossovers use isolated, 16 pin, 8 resistor networks like this, Digi-Key - 4116R-1-273LF-ND (Manufacturer - 4116R-1-273LF)
The 18dB PFMs use isolated, 14 pin, 6 resistor networks
The 6XS doesn't include extra resistor networks, but you can find them for less than $1. The 24dB crossovers use isolated, 16 pin, 8 resistor networks like this, Digi-Key - 4116R-1-273LF-ND (Manufacturer - 4116R-1-273LF)
Thanks fasfocus00 & vaiboy for the answers to aztec's questions.
Like vaiboy said they don't come with xtra resistors just the stock crossover modules that are included described on page 1 of this thread just above the price.
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
