PPI PAR-245 EQ
5 Band Parametric Equalizer
Preamp Line Driver - 10vrms
Choice of 16 Selectable Frequency/Q Settings for Each Band
Front and Rear Outputs with Fader Control
Dual Selectable Illumination (green/red)
Center-Detented Boost/Cut Controls
±15 dB Boost/Cut for Each Band
Defeat Switch
Gold-plated RCA Input and Output Connectors
PWM (Pulse Width Modulated) Power Supply
Independent L & R Input Gain Adjustments
Input Clip Indicator
Designed and Handcrafted in the U.S.A.
Signal-to-Noise Ratio 110 dB
Total Harmonic Distortion (1 kHz, 1 VRMS) 0.002%
Boost/Cut Range ±15 dB
Equalizer Center Frequencies and Q Values:
Band - Frequency - Q Value
Sub (30 - 66 Hz) 2.0 - 3.0
Low (90 - 300 Hz) 3.0 - 5.5
Low-Mid (430 - 900 Hz) 2.5 - 4.5
High-Mid (950 Hz - 4.6 kHz) 2.5 - 6.0
Treble (6 - 16 kHz) 1.3 - 3.3
Maximum Input Voltage (Flat) 10 VRMS
Maximum Output (10 kW Load) 10 VRMS
Frequency Response 3 to 100 kHz
Supply Voltage 9 - 15 VDC
Dimensions 4.60"L 6.75"W 0.95"H
Old school PPI, some of the best build quality you'll ever find in an eq. Easily the cleanest sounding and best quality eq i've ever used. ONLY selling this because I have a chance to get back the only other half din eq I loved as much as this ppi (an eclipse 21000 at a very close second to this par-245).
Manual:
http://narbi.free.fr/manuels/Autoradios%20-%20Proc/Precision%20Power/par245.pdf
The pics are a few months old, i'll update the pics tomorrow when i get home.
The eq's face is in good condition, there's a few scratches on the top but they wont be visible in typical dash install. There's also pictured some glue still on the top side of it. I can't remember if I had removed the glue or not. The only wear on the eq not in this pic are the small scratches on the top i just mentioned. the face is still in great shape.
$150 + exact shipping FIRM
....not $140 shipped, not $150 shipped, not $155 shipped. I'm not interested in how much you saw another one for. If I dont get asking price i'll keep it. It's only getting more and more rare every year.
Not really looking for trades unless it's an offer I cant refuse. I'd just be reselling whatever I trade for so it'd need to be something that'll go quick for 150 or more.
Fedex or USPS
INSURED
Ref's: Years of selling here, you're in good hands:
PM for quotes or with any questions
PPI PAR-245 EQ
Defeat Switch
Manual:
Fedex or USPS
INSURED
