FS: AudioControl 6XS Electronic Crossover
$LICK CALIFA$
I'd give it a 9/10 cosmetic & 10/10 mechanical - the smudge on the bottom can be wiped off. Doesn't come with the power plug (but still works!) or the bass remote but you can get the plug on ebay for less than $10 shipped.
The manual can be found here... 6XS 6 Channel Electronic Crossover
AudioControl's 6XS 6-channel crossover uses a steep 24 dB per octave slope to separate your high and low frequencies, along with a built-in line driver that'll beef up the signal from an anemic receiver.
The 6XS crossover features front, rear, and subwoofer inputs, along with four sets of outputs: front high-pass, front low-pass, rear high-pass, and subwoofer. It comes preloaded with crossover modules that will work in a number of system configurations, but you can change the crossover point by buying another AudioControl module, or by modifying the modules installed in your 6XS. A built-in filter cleans up extreme subsonics in your signal so your amps and subs will play louder and cleaner.
Features:
6-channel Linkwitz-Riley electronic crossover
white steel chassis with gold-plated RCA jacks
line driver with adjustable output (up to 9 volts)
top-mounted controls for easy adjustment
6-channel inputs (front, rear, sub)
balanced inputs eliminate noise
PFM subsonic filter (18-100 Hz at 18 dB/octave)
frequency response: 10 to 100,000 Hz
signal-to-noise ratio: 110 dB
maximum output level: 9.5 volts (13v peak)
fuse rating: 2 amps
size: 7-1/4"W x 1-1/4"H x 7-3/4"D
8-channel outputs:
front high-pass: 250 Hz and up @ 24db
front low-pass: 90-250 Hz @ 18db
rear high-pass: 250 Hz and up @ 24db
subwoofer: 30-90 Hz @ 24db
subsonic filter: 33 Hz @ 18db
$150 Shipped OBO
Included in price
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
