Sold FS: Arc Audio 2300 SE
nismos14
1. Product:
Arc Audio 2300 SE (Signature Edition)
2. Specs:
* Balanced inputs
* 12dB or 24dB slopes on both highpass and lowpass
* All channels are bandpassable
* Bass Boost is adjustable for frequency and level
* Microprocessor controlled to adjust to different ohm loads
* Speed controlled fan cooling
2 Channels @ 40hms 330 Watts 72A
2 Channels @ 20hms 650 Watts 147A
2 Channels @ 10hms 650 Watts 184A
1 Channels @ 80hms 660 Watts 72A
1 Channels @ 40hms 1300 Watts 147A
1 Channels @ 20hms 1300 Watts 184A
Frequency Response 4Hz - 100KHz
Crossover Range 30Hz - 550Hz (x10 300Hz - 5500Hz)
Bass Boost 0 - 15dB @ 20Hz - 80Hz
S/N Ratio (a wtg) ref 1Wall 40hm >86 dB
Seperation @ 1kHz >78 dB
Dampeninig (25W 2x40hm 100Hz) >1000
Low Level Imput Sensitivity .3V - 4V
Balanced Input Sensitivity .6V - 8V
High Level Input NA
Max Peak Current 20hm Mono 222A @ 1800 Watts 10% THD+N
Efficiency at rated 2ohm Stereo 61%
Idle Current 1.50A
Dimensions 191/2 "(L)X8"(W) X21/2 "(H)
3. Description:
This amp is used, but in pretty good shape, pics will describe all. It is a monster of an amp and is one ohm stable, it can be bridged itno 4 ohms and give well over 1300 rms or bridged into 2 ohms and do the same power, it is a VERY versatile amp.
4. Condition:
Used but in good shape, some minor cosmetic issues, but works 10/10
5. Price: :
$550 shipped
6. Pictures:
nismos14
nismos14
Jersey
nismos14
    Jun 20, 2026
    Jun 20, 2026
