FS: AQ HDC3 15 Aluminum Coil
  • 2
Rickdod3
Freshly Reconed 15" AQ HDC3 15 Aluminum coil dual 1
This sub was reconed about a month ago, since then it has had about 15 burps on it from my saz 3500.
Both coils read 1.7, if you dont believe me that its a dual 1 aluminum I can take a picture of the box the recone came in lol
It is still very stiff and performs flawlessly. The only "issue" with it is the recone from AQ they skimped out on the glue around the coil that attaches the spider and after a couple burps I noticed it started to crack in one spot so I took a hefty amount of epoxy and fixed it. It works 100% fine.
10/10 Mechanically 10/10 Physically.
$250+ Shipping.
Open to trades, looking for DD9512 or IA DP 12 etc. Will add cash if necessary.
Buyer pays shipping. Will ship UPS, FEDEX, USPS whatever the buyer prefers.
my aq hdca3 reads 1.2 ea coil. someguy said he thinks the coils are going, apparently not at all.
anyway, great woofer guys, and a good price. bump for some aq!
my aq hdca3 reads 1.2 ea coil. someguy said he thinks the coils are going, apparently not at all.anyway, great woofer guys, and a good price. bump for some aq!
Yeah well my multimeter is a $10 p.o.s lol plus DMM read resistance not impedance so its hard to get accurate...but yeah they read 1.7 right out of the box
I would face the port and sub back. Even if you got a soft top, the rear gate will serve as a loading wall. I looked at the specs for the 10w6v3...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
629
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
Rickdod3
Rickdod3
Centralia, IL
Rickdod3
