Sold FS: Alpine PDX-4.100 - $250 OBO
sundownz
Pro Seller
Supporting Vendor
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
CEA-2006 Power Ratings
* CEA-2006 Power Rating: (4/2 I?@14.4V Ƈ%THD+N), S/N 76dBA (Ref. 1W into 4 I?): 100w x 4
RMS Power Ratings
* Per channel into 4 Ohms: (@14.4V Ƈ%THD+N, 20Hz - 20kHz) 100W x 4
* Per channel into 2 Ohms: (@14.4V Ƈ%THD+N, 20Hz - 20kHz) 100W x 4
* Bridged 4 Ohms: Bridged into 4I? (Ƈ%THD+N) 200w x 2
Sound Tuning
* Crossover: Variable, 30-400Hz (-12dB / oct ), Low-Pass/High-Pass /OFF Selectable
Dimensions
* Heat Sink (WxHxD) mm: 257mm x 192mm x 62mm
* Heat Sink (WxHxD) in: 10-1/8'' x 7-9/16'' x 2-7/16''
General
* Power Requirements: 14.4V DC (11V to 16V)
* Input Sensitivity: 0.2V to 4.0V (For Rated Power)
* Frequency Response: 20Hz - 20kHz (+0, -1dB)
* Speaker Impedance: 4 or 2 I?
* Signal to Noise: CEA 2006 S/N Ratio (IHF A Weighted, Reference: 1W into 4I?) 76 dBA
this is one of the amps i'm considering using for a new project, but i am unsure what to think of the power ratings.
did you test output? i find it hard to believe 100 watts at 4 ohms and at 2. i know alpine rates it at that, but it just seems silly
this is one of the amps i'm considering using for a new project, but i am unsure what to think of the power ratings. did you test output? i find it hard to believe 100 watts at 4 ohms and at 2. i know alpine rates it at that, but it just seems silly
Same thing that JL does with some of their amps, and what Phoenix Gold did with their Xenon series...nothing too strange about it.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
