Sold FS: Alpine, MB Quart, Polk Audio, PIAA, Orion, ETC.
SentraStyle
I have an a brand new Alpine CVA1006 up for sale. This is a great peice for the price. I am looking to get $650 for it. Here are some specs:
• 45W x 4 MOSFET Amplifier
• 6.5” Fully Motorized Monitor
• Bass Engine®
• "Digital-Art" Spectrum Analyzer Display
• Max-Tune SQ Tuner
• Ai-NET Control Center
• 2 Auxiliary A/V Inputs
• Dedicated Navigation Input
• Auxiliary Monitor Control Output
• Dual-In Circuit
• Rotary Encoder Volume Knob
• Navigation Audio Mix
• Wireless Remote Control Included
• Subwoofer Level Control
• Front, Rear, And Subwoofer Preout - 4V
Shipping will be about $20.
_____
I have a Brand New set of Alpine's high end Type X 6.5" component set. Thses are without a doubt one of the best speakers in it's price range. Not only do they sound great, but they look good and have a great build quality as well. These speakers retail for $400, I'm looking to get $250 for these. Here are the specs:
• Bass Engine Ready
• Custom Cast Aluminum Frame
• Low Distortion Magnet Type
• Airflow Optimized Dual-Flare Pole Vent
• Integrated Spider Landing & Heat Transfer Plate
• Low Loss Rubber Surround
• Semi-roll NBR Surround Material
• Hemp Fiber Woofer Cone
• Phase-Integrated Dustcap
• 26mm Soft Dome Tweeter
• Ultra High Quality 2-way Crossover
• On/Off Axis Compensation
• Bi-Wire Input and Selectable Tweeter Attenuation
• Swivel-Flush/Swivel-Surface/30¯ Angle Tweeter Mounting
• Custom 17mm/16mm Adapter Plate
Features:
• Bass Engine Ready
• Bi-Wire Input and selectable Tweeter Attenuation
• Ultra High Quality 2-Way Crossover Tweeter
• Flush, Surface & Angle (W/swivel) Mounting Kits Woofer
• Curved NRSC Diaphragm Shape
Specs:
• Frequency Response : 35Hz - 35 kHz
• Impedance (Nominal) : 4 ohms
• Power Handling: 240 watts peak/ 60 watts RMS
• Mounting Depth (Tweeter) : 26.5mm / 1.0"
• Mounting Depth (Woofer) : 70.8mm / 2.7"
• Mounting Diameter (Tweeter) : 44.5mm / 1.7"
• Mounting Diameter (Woofer) : 132.1mm / 5.19"
_____
I have a brand new set of MB Quart PSD213 5.25" component set for sale. Thses are the "Premium Series" speakers from MB Quart. Anybody that is familiar with MB Quart knows what these speakers will do. They sold for $579.99...I'd like to get $250 for them. Here are some specs:
5.25" 2-Way PREMIUM Separate Components (PSD213)
• Impedance: 4 Ohms
• Frequency Response: 52-32k
• Power Range: 40-100Watts
Contents:
• PTD 25: 1" (25mm) PREMIUM Series Neo Tweeter
• PWD 130: 5.25" (130mm) PWD Midrange Driver
• PXD 213: MUSiCOMP Crossover for the PSD213
• Mount: 25NX Angle: Angle Mounting Ring for 25NX Tweeters
• Mount: 25 NX Flush: Flush Mounting Ring for 25NX Tweeters
• Mount: 25 NX Surface: Surface Mounting Ring for 25NX Tweeters
• QM 130.78 AUFBAU: Raised mounting ring (.47") for 130.03KX
• QM 130.79 MS EINBAU: Flush Rings & Grilles for 130TX-3
Shipping will be about $12.
_____
I have a brand new set of MB Quart DSD213 5.25" component set for sale. I'd like to get $150 for these. Here are the specs:
5.25" 2-Way DISCUS Separate Components (DSD213)
• Impedance: 4 Ohms
• Frequency Response: 55-32k
• Power Range: 35-90Watts
Contents:
• RTC 19 (19NX): .75" (19mm) Reference Neo Tweeter
• DWC130: 5.25" (130mm) Discus Midrange Driver
• DXD 213: Crossover for DSD213
• Grill 19NX: 0.75" (19mm) NX Tweeter Grill
• Mount: 19NX Angle: Angle Mounting Ring for 25NX Tweeters
• Mount: 19NX Flush: Flush Mounting Ring for 19NX Tweeters
• Mount: 19NX Surface: Surface Mounting Ring for 19NX Tweeters
• QM 2213.79 MS: Surface Rings & Grilles for 2213 and 130TX-2
_____
I've got two sets of Polk Audio dX3065 6.5" component sets for sale. I've got one new set and one used (but in perfect condition) set. I'd like to get $175 for the new set and $150 for the used. I've had some offers but they all fell through. Here are some specs:
• Blue tri-laminate silk composite dome tweeters for more accurate response, superior detail and high power handling: "Bright Without Bite."
• Dynamic Balance mineral-filled polymer cone driver for clear, well-defined midrange and great bass, too.
• Pivoting tweeter allows you to aim the tweeter in the direction that yields the best high frequency response and soundstaging.
• Neodymium (NdFeb) magnets offer powerful magnetic energy from small magnets. You get great sound and a speaker so small that it is easy to fit and mount in a wide variety of locations.
• Three-position tweeter level switch for precise high frequency optimization for your car.
• Adjustable crossover point and slope provide 12 different combinations of settings, allowing you to precisely tailor the system sound to suit your car's acoustics and your ears.
• Coated baskets and gold plated terminals resist rust and corrosion for years of reliable performance.
• Polk’s Dynamic Balance® technology for superior response with all kinds of music.
• High-tech Elastomer rubberized-plastic surrounds for reliable durability and better tuning.
• Aramid fiber spiders—the same material used in bulletproof vests—for linear response and wider dynamic range.
• Extra long, precision wrapped, vented voice coils for superior cooling, longer linear throw, and high power-handling.
• Flush and surface mount tweeter mounting cups are supplied.
Driver Complement:
• Mid/Woofer - 6-1/2" Diameter (16.51cm)
• Polymer Composite
• Tweeter - 1" Diameter (2.54cm)
• Tri-Laminate Silk Composite Dome
Electrical:
• Overall Frequency Response: 45hz-20khz
• Nominal Impedance: 4 ohms
• Minimum Impedance: 4 ohms
• Recommended Amplifier Power: 5 - 100w
• Power Handling (continuous): 40 w
• Power Handling (peak): 130 w
• Efficiency 90 dB
Crossover:
• (switch position A) LPF 3.8KHz 2nd order Butterworth HPF 3.8KHz 2nd order
• (switch position B) LPF 3.8KHz first order Butterworth HPF 3.8 KHz 2nd order
_____
I've got two brand new Orion XTR series 10" dual voice coil subs for sale. I'd like to get $150 for thses subs. They will fit in just about any type of enclosure (sealed, ported, etc.). Here are some specs:
• Dual 4 Ohm Voice Coil (2 ohm -series, 8 ohm - parallel)
• 500 watts Peak power handling / 250 watts RMS power handling
• Sensitivity: 96dB (2 ohm)/ 90 dB (8 ohm)
• Outside Diameter: 10.5"
• Mounting Diameter: 9.187"
• Mounting Depth: 4.75"
• Basket Displacement: 115 cubic inches
• Voice Coil Diameter: 2.0"
• Fs (free air resonance): 28 Hz
• Qms (mechanical Q): 8.75
• Qes (electrical Q): 0.30
• Qts (total Q): 0.29
• BL (force factor): 16.4TM
• Sd (piston area): 325 square cm
• Vas (volume acoustic suspension): 84 Liters
• Xmax (linear excursion): 5.25 mm
Enclosure Recommendations:
• sealed: 0.85 cu. ft.
• vented: 1.25 cu. ft.
• port diameter (inside diameter): 3"
• port length: 10"
Shipping will be about $25 for the pair.
_____
I have a used but in flawless condition Bazooka El1500 mono amplifier. I would like to get $75 for this amp. Here are the specs:
• Channels: 1
• Frequency Response: 20-200 Hz
• Fuse: 4 x 15A (60)
• Crossover: Low Pass
• Variable Low Pass Crossover: 40 Hz - 200 Hz
• Crossover Slope: 12dB/Octave
• Protection: Thermal, Short Circuit, Overload
• Max Power Output: 600 Watts
• RMS Power @ 4 Ohm: 350 x 1
• RMS Power @ 2 Ohm: 500 x 1
• Signal To Noise Ratio: >90dB
• THD: 0.03%
• Hi Input Level: 1.0 V - 10.0 V
• Low Level Input: 200 mV - 6 V
• Battery Voltage Range: 10.5 V - 14.4 V
• Bass EQ: 0 - 12 dB @ 45 Hz
• Remote Control (Bass Controll): Optional
Shipping will be about $15.
_____
I have a set of PIAA 002X Xtreme White Driving Lights for sale. I have a set of these on my car and love them. These were bought for a friend who never paid me for them so I have to sell them. They are Brand New and sell locally for $150, I'd like to get $85 for them. Here are some specs:
• 12V - H3 35 watt Xtreme White bulbs
• Black housing
• Compact size for easy installation
Kit contains:
• (2) 002X Xtreme White lamps with universal mounting brackets
• One complete wiring harness with relay and switch
• Installation hardware and wiring diagram
Shipping will be about $10.
_____
I have a set of PIAA Xtreme White Driving Lights for sale. They are Brand New and sell locally for $150, I'd like to get $85 for them. Here are some specs:
• 12V - H3 55 watt = 110 watt Xtreme White bulbs
• Black PPS housing, ultra light weight, and compact
Kit contains:
• (2) 004X Xtreme White lamps with universal mounting brackets
***The picture below is the same as the one I'm selling but in black instead of silver***
_____
I have many references available, and have perfect feedback on ebay under user ID: Droopydogg. I accept checks, money orders, and of course paypal (add 3% for paypal). If you are interested I will entertain questions. But if you do not intend to buy, please have the courtesy to refrain from post dumping. Thanks.
SentraStyle
SentraStyle
Kissimmee, Fl
SentraStyle
