FS Addictive Audio 200.1, Arc Audio XXD2080, Boston Acoustics GTA-800m
srb
Audio XXD2080,
Addictive Audio 200.1- Not bad cosmetically, a few scratches here and there but nothing major, its biggest problem is that it makes some weird sounds some times when you first turn the car on. Like a high pitched whining. It usually stops after a few minutes. Has never cut out or anything though, and puts out tons of power.
8/10 cosmetically, 8/10 mechanically
Arc Audio XXD2080- Almost new. I bought it,tested it to make sure it worked, and put it back in the box. I peeled the plastic cover off and put back on.
10/10 cosmetically, 10/10 mechanically
Boston Acoustics GTA-800m- Works fine, has a few hairline scratches on top, but a lot of bad scratches on the bottom of the amp, but you cant see them unless you have the amp mounted upside down for some reason.
8/10 cosmetically, 10/10 mechanically
Addictive Audio 200.1-$250 shipped
Audio XXD2080-$100 shipped
Boston Acoustics GTA-800m-$150 shipped
Included in price. The Boston and Arc should fit in USPS flat rate boxes, The Addictive will probably be shipped UPS.
This is my first sale online, but I have bought a few things from some members on here.
Item Pictures: View attachment 26535725View attachment 26535726View attachment 26535727View attachment 26535728View attachment 26535729View attachment 26535730View attachment 26535731
that ADS 200.1 is a very nice amp.... should do rated with out any issues.. might want to show some gut shots of it to let some people see them...
rated at 800w @4ohm.. 1400w @2ohm.. 2200w @1ohm... can't remember if these can be ran at .5ohm or not tho.
Its not rated at .5 ohm but as long as you have the voltage it should be able to handle it I think. As far as I know its every bit as good an amp as the AQ 2200, DC 2k, etc.
I've seen a few of them in person, never ran any of the ADS stuff but heard good things about them... can you take some gut shots of this one?
I got it off a guy on Florida spl maybe 2 months ago.
---------- Post added at 07:35 AM ---------- Previous post was at 07:35 AM ----------
Im interested in the 200.1 but where did you get it ?
Specs for Arc XXD2080
Power output RMS @ 4 ohms 2 x 80 watts
Power output RMS @ 2 ohms 2 x 120 watts
Power output RMS @ 4 ohms bridged 1 x 240 watts
Transient Distortion (100 watts) Frequency Response 20Hz - 20 KHz
Signal to Noise Ratio >83dB
Bass Boost +12db@45Hz
Crossover (Butterworth) High (65Hz - 250Hz) / Low (50Hz - 250Hz)
Gain Range .25V - 4.0V
Size 6 1/2" (L) x 7 1/8" (W) x 1 7/8" (H)
Specs for Boston GTA-800m
500 watts RMS x 1 at 4 ohms (800 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
variable low-pass filter (50-150 Hz, 12 dB/octave)
variable subsonic filter (10-50 Hz)
Q-Tune technology variable bass boost
optional wired remote subwoofer level control
Symmetrical Signal Technology (SST™) uses asymmetrical balanced inputs for noise cancellation
frequency response: 10-150 Hz
preamp and speaker-level inputs
fuse rating: 40A x 2
4-gauge power and ground leads recommended
THD 0.05%
12-9/16"W x 2-3/8"H x 8-9/16"D
link to specs for Addictive 200.1
ELITE SERIES - Addictive Audio
srb
srb
Lake County, Florida
srb
