^^^, with bass knob
Good condition, just acquired this last night. Works great, has some minor blemishes on the fins and a couple Knicks on the top. I have a copy of the birth sheet as I didn't have time to go back and get it, the guy scanned it and emailed it to me. Birth sheet states 2719x1 @2 ohms. I've heard you can run these at 1 ohm if you have a stout electrical and its before box rise. Should do 3k+@1 ohm easily, wouldn't recommend it for daily though.
ZX Series Class D Monoblock Car Amplifier
RMS Power Rating: 4 ohms: 1250 watts x 1 chan. 2 ohms: 2500 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through RCA connection, Kicker 09ZISL required and sold separately Preamp RCA outputs
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Variable low-pass filter (50-200 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 25 Hz)
CEA-2006 compliant amplifier
Frequency response: 25-200 Hz
Dimensions: 27-1/2"L x 9-5/8"W x 2-1/8"H
1/0-gauge power and ground leads recommended
10/10 mechanical
8/10 cosmetic
$500obo shipped, no trades
Included
^^^, with bass knob
MOSFET power supply
10/10 mechanical
8/10 cosmetic
Included
