Sold FS: 4 Digital Designs 9512Gs
jbizzle
Item:
Specifications:
DD9500g Series Subwoofers - DDAudio.com | Digital Designs : Speakers Made in the USA
Description:
Come with 8" Carbon Fiber dustcaps and low impedance option (Dual 1).
Condition:
Recones are only a few months old, still pretty stiff.
One sub has a slight hole in the surround from a screw, not really noticeable if I didn't tell you, but it has been fixed from the under side. (See pictures)
$450 each OBO local, if you want them shipped you must pay actual packaging/shipping.
Pictures:
For the impedance pictures, subs are wired in series hence the 2 ohm load.
SPECIFICATIONS
Series 9500g
Voice Coil Diameter 3"
Magnet Weight 406 oz
Power Handling RMS/Peak 1500/6000
Suspension 80 mm
Nominal Impedance D .5, D .7, D1.0, D1.5, D2.0, D4.0 Ohm
DC Resistance .5 - 3.6 Ohm
Model 9510g 9512g 9515g 9518g
Rec Box (cubic ft) 1.6 2.6 4.25 6
Port Area (sq in) 26 42 70 100
Port Length (inches) 23 22 21 20
Woofer Diameter 10" 12" 15" 18"
Free Air Resonance
35 Hz 34 Hz 33 Hz 29 Hz
Qts 0.25 0.31 0.29
Qes 0.27 0.33 0.31
Qms 3.1 4.15 4.32
Vas 15L 35L 85L
Sensitivity 87 dB 89 dB 93 dB 94 dB
Shipping Weight 50 lbs 51 lbs 55 lbs 61 lbs
jbizzle
jbizzle
Chicago, IL
jbizzle
